I smell coolant?
Old May 6, 2016 | 02:30 PM
dani3ln3al's Avatar
dani3ln3al
Default I smell coolant?
So about 6 months ago I had to replace my radiator and a few other parts due to a leak. I have not had a problem since then; no overheating or anything. The only issue I've had is that if the engine is running and the car sits still for like 10+ minutes, I will start to smell coolant. This only happens when my car is sitting still, like I could drive my car around for an hour, park my car, turn it off, and I would never smell it. But if I leave it running while it sits in one place for just a few minutes I can smell it. I'm sure it's nothing serious because this has been going on for 6 months and I've never had an actual problem with the car, it's just annoying and I want it to go away haha.
Any idea what it might be?
Old May 8, 2016 | 09:37 AM
0jiggy0's Avatar
0jiggy0
Coolant leaks are never serious....
Get a pressure tester on the car, it is the best way to find a leak.
Old May 8, 2016 | 10:49 AM
HRMoneyPit's Avatar
HRMoneyPit
My HR has always smelled like coolant. When I upgraded the rad I changed the thermostat and gasket that it was leaking from and while it was all open u saw nothing else anywhere. So I figured that was the problem......welp to this day it still smells like coolant with no sign of where is coming from. I gave up
Old May 8, 2016 | 12:19 PM
0jiggy0's Avatar
0jiggy0
Check under the interior carpets. Could be the heater core.
Old May 8, 2016 | 12:34 PM
HRMoneyPit's Avatar
HRMoneyPit
You don't smell in the car. Only when your in front the car. And obviously when you pop the hood
I never have to add coolant I can just smell it
itzlen
May 8, 2016 05:32 PM
jdm-v35
May 5, 2016 06:54 PM
Kellys7118
May 5, 2016 02:38 PM
Speertjuhh
May 3, 2016 08:20 PM
