Quick AC question
Old Jun 20, 2016 | 11:59 AM
turboed350z's Avatar
turboed350z
Originally Posted by MicVelo
Not really a "check freon" method but.... IF (meaning, not sure if Z has one or not, never looked and never incidentally seen one) the Z has a sight glass in the high side line (liquid line) from the condenser, this can tell you a few things but not that accurately.
With the car and a/c running, the movement of the fluid through the sight glass should be free and clear of any bubbles. If there are bubbles, system is definitely low (but again, that's all it says.... "low"; not "how low".)
However, even if the sight glass if free of bubbles, that doesn't mean the system is OK. It's just a thumbnail view of what's going on inside and it's more of a warning: "if there are bubbles, you have issues"
Im pretty sure the z doesnt have that, but i just learn something new today. So still happy haha
Old Jun 20, 2016 | 01:44 PM
turboed350z
ran to walmart, bought a recharge kit, charge it and now its blowing cold air. if it doesnt hold up, then i will have to find the leak.
side note, i need a new "L" cap... oem is a bit too big for mine.
Old Jun 20, 2016 | 02:55 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Good job, T'bo! Please report back on this in a couple/few weeks just so people know what to expect.
Old Jun 20, 2016 | 03:13 PM
turboed350z
will do. i bought the gauge and a 5 dollar can of r134a. 5min and the ac blows cold.
lets hope theres no leaks. so far the pressure was holding. but still too soon to tell.
Old Jun 21, 2016 | 03:27 AM
92K1500's Avatar
92K1500
If it needed freon put in, it has a leak. It doesn't just go away. My 93 F150 has never needed topped off on freon and it still blows cold.
Old Jun 21, 2016 | 05:08 AM
turboed350z
Really? I was always under the impression that it was a maintenance item type thing. Admittedly ive never have a car long enough to ever required it, but it was just my assumptions.
Old Jun 21, 2016 | 07:01 AM
MicVelo's Avatar
It is a "maintenance item" SORT OF. Older car, compressor seals wearing from drying out (which is why it's a good idea to run the A/C at least once a week) resulting in slooooow leakage.
Just a natural age progression thing. Some do it, some don't.
Old Jun 21, 2016 | 08:28 AM
rancor's Avatar
rancor
An AC system should not leak if it is working correctly. I have heard it helps if the system is used frequently so try to use it more often that one a year.
EDIT- looks like MicVelo said it better
Old Jun 21, 2016 | 08:37 AM
turboed350z
Yea i think thats the problem then. It probably has a small leak. The car gets taken out maybe once a month and almost never during summer. 100+ degree with turbo is never fun so i avoid it. Ill probably start using it more and run the ac more now. If there is a leak ill remember to run it once a week haha
Old Jun 28, 2016 | 07:17 AM
turboed350z
Been over a week since i recharged it. Ac is still blowing cold. If i do have a leak, its a VERY small, slow leak.
Ill update in a month to see whats up
Old Jun 28, 2016 | 06:34 PM
Tickytack's Avatar
Tickytack
Default AC Leak Question
I have an AC Leak on my Nissan 350z (2005). I have taken off the intake manifold and injected AC Leak Die on the low side with the engine off. I do not see any leak using a Black UV Light on the low and high side AC Lines. I see a glow along the joint for a bigger hose running from right to left below the AC System/ Engine. What is that hose because I notice a puddle of UV Leak Die on the bottom of the tray most likely coming from that bigger unknown hose?
Responses would be greatly appreciated!
Old Aug 4, 2016 | 02:07 PM
turboed350z
Been a month and so far, the charge has held up fine
Old Aug 4, 2016 | 02:48 PM
MicVelo's Avatar
Dude!!
For some odd reason, this morning as I was doing the mod thing checking everyone's behavior (laff!), I thought, "Hey, where's T'bo at? Haven't seen him wreaking havoc on anyone's ego lately."
Hahahahahaha!l Welcome back, pops (to be).
Old Aug 4, 2016 | 09:48 PM
i8acobra's Avatar
i8acobra
It's one of the a/c hoses. If it's leaking from a joint, it's just a bad o-ring. If it's leaking from a crimp, you need a new hose.
Old Aug 5, 2016 | 02:21 AM
HRMoneyPit's Avatar
HRMoneyPit
My AC sucks in the Z. I have to drive forever for it to be decently cool after its been in the sun all day
I've been needing to take it some where and have it checked
Robbie05
May 29, 2017 04:42 PM
Nfaile350z
Jun 23, 2016 05:18 AM
CristianTR
Jun 15, 2016 06:25 AM
Turbo_Tay
Jun 9, 2016 11:04 AM
nomyth46
Jun 9, 2016 07:07 AM
