Oil ball leak? Help!
Old Jun 30, 2016 | 12:39 PM
Crawford842's Avatar
Crawford842
Default Oil ball leak? Help!
I have no idea how to fix this. Oil flows freely from what appears to be something like a ball bearing. I've got a picture of the area from someone else who had the problem.
This is right behind the oil pressure sensor.
Old Jun 30, 2016 | 01:01 PM
rancor's Avatar
rancor
Replace the upper oil pan would be my guess. The ball bearing is most likely an interference fit part used to seal the hole after the machining operation used to create the oil passage.
Old Jun 30, 2016 | 01:46 PM
i8acobra's Avatar
i8acobra
Put a punch on it at tap it to re-seat. The Titan had an issue with one of those on the block behind the alternator. Nissan's fix was to remove the alternator, tap the ball to re-seat, then reinstall the alternator. I assume the same will work for this. If not, try to drill it out, tap the hole with a 1/8 NPT tap and thread in a plug.
Old Jun 30, 2016 | 05:33 PM
Crawford842
Replacing the upper oil pan was the guess that the guy at Stadium Nissan's part desk had for me.
Old Jun 30, 2016 | 05:35 PM
Crawford842
Yeah I'll try whacking it to see if that fixes it. If not, I'll plug it up. What kind of plug would you suggest? One with a spring to allow pressure past? Or just seal it off?
Old Jun 30, 2016 | 07:06 PM
i8acobra's Avatar
i8acobra
You need to tap just the ball, so you'll need a punch. If it still leaks, you need to drill the ball out, tap threads into the hole and plug it with one of these:
Or, one like this:
Old Jul 2, 2016 | 01:23 AM
Crawford842
Or, one like this:
I tapped it using a 3/8"-1/4" socket adapter on a 3/8" extension. I haven't checked to see if that fixes it. If it doesn't, I'll borrow a drill and give that a shot.
Old Jul 9, 2016 | 12:17 PM
Crawford842
Or, one like this:
So I tried drilling it; the bit keeps traveling around the ball and won't bite. Any recommendations?
Old Jul 9, 2016 | 03:05 PM
i8acobra's Avatar
i8acobra
JB Weld. Spray it out real good with brake clean, dry it with compresed air, then fill the hole with JB Weld. That should stop the leak. If it doesn't, the JB Weld might at least keep the ball still so you can drill it out.
Old Jul 12, 2016 | 05:39 PM
Crawford842
Ill pick up some jb weld tomorrow. I've already tried knocking that ball through but it won't go any further.
The plug that I got is slightly too large and my tap and die set is incomplete.
I think it's possible that the ball may have seated itself to stop the leak, however I'll just get jb weld so I don't have to put everything back together and refill the fluids just to test it and find it still leaking.
Old Jul 13, 2016 | 01:30 AM
i8acobra's Avatar
i8acobra
You wouldn't see it move. The amount it moves to reseat is less than a mm.
Old Jul 13, 2016 | 07:05 AM
Crawford842
I meant it may have seated itself from hitting it in as far as I could.
Old Jul 13, 2016 | 07:07 AM
Crawford842
I was trying to hit it through but it won't go any further so I think it's seated in metal. Still gonna try to seal it with body filler or J-B weld
Old Jul 14, 2016 | 12:43 AM
i8acobra's Avatar
i8acobra
It won't go through. It's press fit in a hole slightly smaller than it. It sits on a "seat".
Old Jul 14, 2016 | 07:12 AM
iideadeyeii's Avatar
iideadeyeii
jb weld wtf. I'm not even that ghetto
Old Jul 14, 2016 | 07:28 AM
rancor's Avatar
rancor
One of the MEs I work with recommended loctite sealant or a pipe plug like Crawford842 suggested. Once that ball bearing has come loose the aluminium it's pressed in is already deformed so reseating it is not ideal but if it works it works.
Old May 5, 2020 | 06:55 PM
Bak3rme's Avatar
Bak3rme
bumping old thread. Has anyone figured what this ball is used for?
Old May 6, 2020 | 06:02 AM
rancor's Avatar
rancor
It's a cheap way to seal a drilled hole. They needed to drill in that location to make part of the oil passage but now also have a hole that leads to the outside. The passage was probably needed to get the pressure sensor oil. The way to seal the hole is with a pressed in ball bearing or do additional machining operation and tap the hole for a pipe plug. Pressed ball bearing is less expensive.
Old May 6, 2020 | 10:29 AM
Bak3rme's Avatar
Bak3rme
I'm trying to envision what is behind the ball and how it seats up to it. Also that would help me understand how its prone to leaking like the others above.
Old May 6, 2020 | 09:05 PM
i8acobra's Avatar
i8acobra
It's a machined seat. The ball sits flush against the seat.
