Stall on Starup...
Old Jul 1, 2016 | 07:41 AM
HCO_surfer's Avatar
HCO_surfer
Default Stall on Starup...
So this issue is intermittent...
2004.5 350z touring always changed oil at 5k intervals and always 93 premium fuel.
I start my car in first and have the clutch in but sometimes the rpm will drop very low to 0 and stall. Other times it will go very low and almost stall but then go back to where it should at about 800.
I've searched and have cleaned both my maf and air filter. I then reset the ECU and drove roughly 500 miles.
Any ideas?
Old Jul 1, 2016 | 08:14 AM
travlee's Avatar
travlee
Master
cam position sensors
Old Jul 1, 2016 | 08:47 AM
HCO_surfer's Avatar
HCO_surfer
I looked for pending or stored codes and didn't see any. should I replace both the driver and passenger?
Old Jul 1, 2016 | 09:02 AM
travlee's Avatar
travlee
Master
Some time they throw codes, sometimes not. I would replace both
Old Jul 1, 2016 | 10:30 AM
HCO_surfer's Avatar
HCO_surfer
Thank you. I actually just reset my ECU and noticed there is a lot of acid buildup on the positive terminal. Could this cause an issue?
Battery is from June 2010, last owner put it in (OEM battery). Voltage is good at about 14 based on the interior gauge.
Old Jul 1, 2016 | 10:51 AM
travlee's Avatar
travlee
Master
could be, try that first...
Old Jul 1, 2016 | 10:52 AM
HCO_surfer's Avatar
HCO_surfer
+1 thanks bud will do. Might replace as its already pretty old.
Old Jul 3, 2016 | 03:34 AM
92K1500's Avatar
92K1500
Clean the battery terminals but I doubt that's it.
Next thing to check for would be vacuum leaks. Mine was doing this same thing intermittently. It ended up being the preformed hose that goes from the bottom of the intake tube to the back of the driver side valve cover. Was split halfway around and sucking in unmetered air depending on temp and how the hose rested when I shut it off.
Check the cheap things first.
Old Jul 3, 2016 | 06:42 PM
HCO_surfer's Avatar
HCO_surfer
Thanks I will have to check that out. Have a road trip coming up so will be putting about 1,000 miles on the z. Could be that it's split I've never really checked my hoses before. Hopefully I can find it.
I'm also going to replace the battery while I'm at it, already 6 years old.
Old Jul 5, 2016 | 09:26 AM
HCO_surfer's Avatar
HCO_surfer
Yep its not the battery. Although I got rid of a lot of corrosion and it was needed to be changed.
I am going to find OEM cam sensors and install both.
Old Jul 5, 2016 | 09:34 AM
travlee's Avatar
travlee
Master
courtesyparts.com
Old Jul 5, 2016 | 09:49 AM
HCO_surfer's Avatar
HCO_surfer
courtesyparts.com
Thanks, how hard is the install ? I've seen vids and pics but just curious.
Old Jul 5, 2016 | 09:58 AM
travlee's Avatar
travlee
Master
one 10 mm bolt per sensor, not that hard. one is harder than the other but i cant remember which one
Old Jul 5, 2016 | 12:59 PM
HCO_surfer's Avatar
HCO_surfer
This is basically what my z does, found a video on youtube... Just got the car so not sure if this is normal.
It doesnt seem to stall after the new battery but still drops then goes to idle.
Old Jul 5, 2016 | 01:52 PM
92K1500's Avatar
92K1500
This is what mine was doing.
This is the hose I was talking about.
Old Jul 5, 2016 | 02:08 PM
HCO_surfer's Avatar
HCO_surfer
04 350z starting issue - YouTube
Thanks for the pic, I did look at that hose among other rubber ones and didn't see a puncture or rip.
I only noticed this stalling issue after my battery was disconnected for a headunit install. After that it seemed like the issue was present. Only had the car a bit though but seems like it can't maintain idle only after a start.
Old Jul 8, 2016 | 06:11 AM
HCO_surfer's Avatar
HCO_surfer
Still persistent randomly but doesn't stall fully.
What I've done this far:
Cleaned maf
Cleaned air filter
Installed new battery
I might reset the ECU at this point or clean the throttle body.
Old Jul 8, 2016 | 06:15 AM
travlee's Avatar
travlee
Master
Originally Posted by hco_surfer
still persistent randomly but doesn't stall fully.
What i've done this far:
Cleaned maf
cleaned air filter
installed new battery
i might reset the ecu at this point or clean the throttle body.
do not touch the butterfly
Old Jul 8, 2016 | 06:27 AM
HCO_surfer's Avatar
HCO_surfer
Okay that makes sense.. I've seen some people have many many issues after touching that. Maybe I'll just take it off to see how dirty it is first.
Old May 25, 2017 | 03:31 PM
davidmrqz3's Avatar
davidmrqz3
Are you stupid? It's obviously the CPS , hope you dont wrap it around a pole.
