dash lights and power mirrors isnt working
Old Jul 20, 2016 | 06:16 PM
tinkbz's Avatar
tinkbz
Question dash lights and power mirrors isnt working
Hello I'm new to the site. I got a great deal on a 2004 350z, but it didn't have a radio only the factory navi unit, i install a aftermarket radio but once i did the dash lights, power mirror and the small information pod stop working.... i have tried..... checking all the fuses (kick panel, fuse panel in front and behind the battery)... all the fuses are good, is there anything else i can try?
Old Jul 21, 2016 | 01:11 AM
Unicus's Avatar
Unicus
I don't know how you messed up the install that badly.
Turn off the radio. Do they work?
Take out the radio. Do they work?
Basic troubleshooting, find where exactly the problem can be by eliminating variables. Come back with some specifics and we can try to figure out what you broke.
Old Jul 21, 2016 | 03:07 AM
tinkbz's Avatar
tinkbz
im not sure what happen, I've done many installs and never had a problem
none of the wires touched, it was a basic install i hooked everything up outside the car before plugging it into the car.
I've turned the radio off. they still don't work
took the radio out. still don't work
took harness out. still don't work
I checked all fuses they are good
Old Jul 21, 2016 | 03:28 AM
Unicus's Avatar
Unicus
If you went back to how it was before and it doesn't work you either shorted something out or burnt something. Gotta check from there, check the manual and the electrical diagram to see if your problem areas share a common fuse/ground etc.
ThomBoh
Southern California
Jun 1, 2016 03:23 AM
phreaktor
Apr 8, 2016 05:33 PM
mechanicaljesus
Apr 4, 2016 04:41 PM
CK_32
Apr 1, 2016 08:06 AM
350z_Gio
Suspension
Mar 23, 2016 05:51 PM
