Air bag light
Old Aug 14, 2016 | 02:19 AM
stendori's Avatar
stendori
Default Air bag light
i had read the sticky "
RECALL* - 2007/08 Passenger Airbag Sensor"
and wondering if my 07'touring roadster has the same issue. i just bought this car a few weeks ago and only have put on 4oo miles and noticed that my air bag light (assuming that is what it is) is flashing all the time while either parked or driving and w/ or w/ out a passenger with me.the car only has 10,400 miles on it. i put my vin# in a search for recalls and it says it has none and i have every slip of paper that has been done to the car since new. any suggestion or advise would be helpful before i decide to take it to a dealer later on. thanks.
Old Aug 14, 2016 | 03:23 AM
karlt's Avatar
karlt
Download a copy of the Service Manual for your car (start here:
http://www.nicoclub.com/archives/use...-database.html)
Open the SRS.pdf section and perform the diagnostics beginning on page SRS-26 (HOW TO CHANGE SELF DIAGNOSTIC MODE WITHOUT CONSULT-III). The air bag warning light flash sequence will then tell you where the problem lies.
Alternatively, you can use a good quality OBD scan tool that reads SRS codes and check against the codes listed beginning on page SRS-29.
Old Aug 14, 2016 | 06:39 AM
stendori's Avatar
stendori
thank you for the info. if i can figure out how to get the down load to come up or down load I'll give it a try as my computer won't even let me down load or view it for some reason. again thank you for the insight as i really didnt want to take it to a dealer if i can figure it out w/ help.
Old Aug 14, 2016 | 11:45 AM
stendori's Avatar
stendori
UPDATE: i found that the coupe/roadster section wouldn't work but the coupe section opened up fine. we found a loose plug in connection under passenger seat and went by the srs section and reset it and light is now out. didn't take it for a ride just backed out of garage and it seems fine. i can't thank you enough.
Old Aug 14, 2016 | 01:44 PM
karlt's Avatar
karlt
Glad you worked it out. Loose connectors under the seats seem to be common problems.
Aug 16, 2016 06:36 PM
Jonp
Aug 1, 2016 11:49 AM
PhiSig
Jul 31, 2016 01:55 PM
Tachiro-X
Jul 19, 2016 04:42 AM
