Nearly hydrolocked the engine. Need some help to work thru the issues.
Old Oct 8, 2016 | 10:09 AM
travlee's Avatar
travlee
Master
Doh....
Old Oct 8, 2016 | 07:34 PM
Gearheadvr4's Avatar
Gearheadvr4
Would it have a bent rod if it still spins over freely?
Old Oct 8, 2016 | 07:52 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Probably not, but if any of the bearings are damaged the end result could be the same: a blown motor. Do you really want to abuse this beautifully built, alloy VQ by running it without properly assessing any water damage?
Old Oct 8, 2016 | 09:14 PM
CK_32's Avatar
CK_32
I checked the oil and it looks like milk. So obviously water got into the oil. Does that happen thru the piston rings?
So now what? Is the engine shot?
Very possible. But if it's that bad you hit one hell of a puddle to do so.
I would also recccomend pulling the block and inspecting full internals.
Old Oct 9, 2016 | 08:47 AM
terrj's Avatar
terrj
Wouldnt it be more cost and time effective to buy a new used engine and be done with it instead of pulling the block and disassemble everything. It's fairly cheap anyway ?
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I stalled in a puddle before also, I traded that car in asap and never got a cold air intake again, I still have the intake in my shed to remind myself.
Luckily my car started back up and didn't have any major issues. (That I was aware of anyways)
Old Oct 9, 2016 | 09:11 AM
dkmura's Avatar
dkmura
A "new, used engine"? What you really mean is a used engine from a totaled car. That is an option, although it means you don't have much idea of what condition that engine is in, outside of what the scrap yard tells you. Another option is to buy a rebuilt shortblock or engine, and use the water-damaged engine as a core. Either way, it's still a serious penalty for misjudging a "puddle".
Old Oct 9, 2016 | 09:39 AM
dboyzalter's Avatar
dboyzalter
Change the oil get to start trade that bad boy into a dealership...
Wouldnt milky oil be a head gasket problem, I cant imagine water from a puddle got into your engine that much.
Old Oct 9, 2016 | 10:53 PM
terrj's Avatar
terrj
Thats what i meant haha and it is what it is man, thats why i dont run CAI. Barely any gain if at all , not worth the trouble
Old Oct 10, 2016 | 07:11 AM
Gearheadvr4
Yeah, not a new engine. Just a salvage engine and use mine as a core to pull parts from. Cheapest I could find so far in Texas is around $1700. I hate to give up on the car since it's in excellent condition and relatively low miles.
Ethically, I wouldn't feel right about passing on a problem to someone else. Even a dealership.
Old Oct 10, 2016 | 09:12 AM
dkmura's Avatar
dkmura
Good on you!
Old Oct 10, 2016 | 09:31 AM
dboyzalter's Avatar
dboyzalter
Dealerships are the worst, I wouldn't feel bad about passing on a problem to a dealership, they would just stick it in an auction anyways...
I wouldn't sell private party though unless I disclosed everything I know...
In your situation I would probably just start taking it all apart.
Old Oct 10, 2016 | 10:40 AM
Gearheadvr4
What is the likelihood that its the head gasket? If water is in the oil then it's all over the engine block and heads. Any way to flush that out?
Old Oct 10, 2016 | 01:06 PM
dkmura's Avatar
dkmura
You're grasping at straws, but the likelihood is higher if you were losing significant compression and engine performance BEFORE the swim. There's no way to shortcut repairing the damage to a flooded engine. After disassembly, you'll need to use a good parts washer and some elbow grease to properly get all the water out. Oil, water and the precision build of your VQ are not a good mix.
CK_32
Sep 20, 2016 07:02 PM
ATIX
Sep 13, 2016 05:46 PM
Steve Mack
Sep 13, 2016 09:56 AM
jhill3757
Sep 7, 2016 03:14 AM
VO...
Sep 4, 2016 09:40 PM
