04 350z out of time?
I bought the car with knowing it had a problem with the motor. I could unplug the #2 coil and it wouldn't change the way the car ran an the car didn't hav hardley any power at all. I did compression test and its 130psi on all cylinders the motor has 129 thousand miles on it. I replaced cam sensors. Coil. And spark plug an still no change. I was driving it back home an it just died. An then I went to start it back an it would start but it would stay running any longer than 5 secs. I had it hauled home an I unplugged the maf sensor an the car started right up an was running lik it was before. But it wouldn't rev past 2500 rpm. An was still no change wen I unplugged the coil. I had to move the car to a garage an I left it overnight at the garage an I went to pull it in the garage the next day an it would only run for 5 secs even wen I unplugged the maf sensors. Did it jump Time a couple teeth or wat. Before it was washing the oil down with gas an filling the oil with gas so it wasn't firing right. Or burning the fuel. I checked the injectors there good. Wat could it be.
