Engine shut off
Old Jun 20, 2017 | 07:01 AM
Alan Sanchez's Avatar
Alan Sanchez
Default Engine shut off
I've recently been having problems with my car shutting off similar to when the camshaft sensors goes bad. Engine dies,power steering goes. I went to AutoZone to get it checked out and they told me it was the Vvt(bank 2). My sister's bf ordered me some new ones but wheb they came in and after installing them we noticed they had the number 6 on them while the ones on my car had 4. So we decided to use the new solenoids with the old casings. For the rest of the day I had no problems till the next morning it happend again and keeps occurring pretty much all day. When I let off the gas at 3-5000rpm (different speed limits where I drive) the idle would drop to about 700rpm. I went to AutoZone and they told me it was the Vvt (bank 2) again. Has anyone ever experienced this problem before and know what I can do?
Old Jun 20, 2017 | 07:31 AM
travlee's Avatar
travlee
Master
did you replace with their sensors or genuine nissan?
Old Jun 20, 2017 | 07:41 AM
Alan Sanchez
No, I took off the solenoid and casings avid put on the new ones, but oil shot out. So I only switch one of the cases with the one it had and oil didn't shoot out, so i replaced the other casing with the one it had. So the casings are the same just the solenoids are different. Idk where he got them from but they were specified for my car.
Old Jun 20, 2017 | 10:13 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Hahahahahahaa.. more of this genuine or generic sensor crap. No offense, OP.
Old Jun 20, 2017 | 10:16 AM
travlee's Avatar
travlee
Master
cheap sensors can cause issues.... just sayin
Old Jun 20, 2017 | 10:31 AM
Alan Sanchez
they're the stock sensors
Atreyu'z 350
Is it shooting oil out of this hole?(see image) Those are generic castings if it is, and need to be replaced with OEM Nissan ones. I would ask your sisters bf where he got them and try to return them as a unit. They're not sensors, technically, so you'll probably be able to.
Old Jun 20, 2017 | 10:36 AM
Atreyu'z 350
I know, trav. It's a legit question. It's just asked so often, and with good reason. That's what I meant.
Old Jun 20, 2017 | 10:39 AM
Alan Sanchez
yea it shot from there. From what we did we used the old casings since those didn't shot oil and we just used the new solenoids from the ones he ordered. We're they suppose to shoot oil
Old Jun 20, 2017 | 10:48 AM
zakmartin's Avatar
zakmartin
You're wrong. It's always a good, reasonable question. So many aftermarket sensors are garbage. Modern cars don't tolerate the aftermarket stuff like older cars did back in the day.
Old Jun 20, 2017 | 10:52 AM
Alan Sanchez
mines is a 04 base model it's pretty much stock except for the suspension, wheels, intake
Old Jun 20, 2017 | 11:03 AM
Atreyu'z 350
Yeah, I read that you had switched the new solenoids to the old castings. Hopefully the new solenoids hold up. I don't have experience with that kind of scenario.
Old Jun 20, 2017 | 11:04 AM
Atreyu'z 350
you're wrong. It's always a good, reasonable question. So many aftermarket sensors are garbage. Modern cars don't tolerate the aftermarket stuff like older cars did back in the day.
yes, i know. It is a good question. Legit = good.
Old Jun 20, 2017 | 11:06 AM
Atreyu'z 350
OP. No, it is not supposed to shoot oil.
Old Jun 20, 2017 | 11:07 AM
Alan Sanchez
they went on just fine except the engine keeps shutting off and it's happening more frequently
Old Jun 20, 2017 | 11:26 AM
Atreyu'z 350
Is your 'check engine light' on? How did Autozone know it was your Bank 2 variable valve timing solenoid? Did they hook it up to their scanner and check for error codes?
Old Jun 20, 2017 | 11:42 AM
Alan Sanchez
it only comes on after the engine shuts off this is the print out they just gave me.
Old Jun 20, 2017 | 11:46 AM
travlee's Avatar
travlee
Master
wow, that is a hot mess of codes
Old Jun 20, 2017 | 12:23 PM
Alan Sanchez
some of then repeat, the cylinder misfire might be due to having a missing bolt on one of the spark plugs, the steering might he because the car doesn't have the stock steering wheel
Old Jun 21, 2017 | 11:15 AM
Atreyu'z 350
lol Holy F***
