Another 2006 oil consumer
Old Jul 31, 2017 | 07:49 PM
jimbucks's Avatar
jimbucks
Default Another 2006 oil consumer
Not where to post. Just bougjt a 2006 350z manual with only 19xxx miles. After 800 miles it was down a quart of oil.
Old Aug 1, 2017 | 05:35 AM
jhc's Avatar
jhc
General & Tech Moderator
Rule out oil loss due to leaks.
Old Aug 1, 2017 | 06:04 AM
Atreyu'z 350's Avatar
Atreyu'z 350
OK.. Did you check for leaks? What troubleshooting have you done?
Old Aug 1, 2017 | 06:46 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Ehhhh, just needs a longer dipstick or to push the one he has in deeper.
Wait, that dint come out right.
Old Aug 1, 2017 | 07:41 AM
iideadeyeii's Avatar
iideadeyeii
Sounds perfect. You never have to do an oil change.
I miss my geo metro that would burn 1qt every ~1k miles. Didn't do an actual oil change for the 3-ish years I owned it.
Old Aug 1, 2017 | 12:09 PM
zakmartin's Avatar
zakmartin
My 1995 Saturn SL1 would burn 1 quart every 800 miles. GM said that was "within specs."
Are you seeing plumes of smoke coming out your tailpipe?
Old Aug 1, 2017 | 03:46 PM
guitman32's Avatar
guitman32
Thats not that bad. Run the cheapest oil you can find and keep her topped off.
Mine burns about that much, albeit with a bad valve cover leak. Has done so for 12 years. I did UOAs for at least 3 years straight, maybe more. All fine, she still purrs like a kitten.
Keep in mind I havent done any PCV or other crankcase mods. I still run 30 weight oil at about 100k on the clock.
If all it does is burn oil, I say just enjoy the car.
Old Aug 1, 2017 | 04:21 PM
e30cabrio's Avatar
e30cabrio
Sorry, I feel your pain.
I bought mine with a "new" motor with low miles that also started using oil at 18k miles.
If I had it to do over (built a zillion $ stroker that blew a cylinder and dumped the car after installing a junk yard motor) I'd just put oil in & enjoy the car.
fwiw
Old Aug 2, 2017 | 06:09 AM
Atreyu'z 350
I'm just surprised at how quickly some of the Rev Ups tend to burn that much oil so early in their life.. I've read some articles about it; From randomly occurring design spec errors to the catalytic converters to improper 'break in' procedures... Apparently there's no singular reason.
Old Aug 2, 2017 | 06:21 AM
e30cabrio's Avatar
e30cabrio
Mine did it at 18k on the original motor. That is why they gave the replacement 12k/ 12 months and said too bad at 18k/ 18 months.
Old Aug 2, 2017 | 07:17 AM
Atreyu'z 350
Amazing. How convenient for them.
Old Aug 2, 2017 | 10:41 AM
e30cabrio's Avatar
e30cabrio
Yup, that is why I'll never own another Nissan & tell anyone I know thinking about buying one that story. I have cost them 27 new car purchases & 22 used cars. (That I know of)
Old Aug 2, 2017 | 11:22 AM
Atreyu'z 350
Hey, the truth hurts. Even indirectly.
Old Aug 9, 2017 | 11:54 AM
trusovici's Avatar
trusovici
I have an 04 with similar consumption. I changed to castrol gtx 10w40 conventional and the consumption was less compared to mobil 1 5w30.
