P0345, CEL, Slip & Traction control light all on!
Old Aug 21, 2017 | 04:15 PM
CityOfSin's Avatar
CityOfSin
Default P0345, CEL, Slip & Traction control light all on!
Having some issues with my 04 350z. Its throwing code P0345 with my slip & traction control light on aswell. The code indicates a fault in the bank 2 camshaft sensor A. Ive replaced the sensor & the car is still acting the same. I went ahead & replaced the other cam sensor & crankshaft sensor as well & no luck. The car cranks for 4-5 seconds but turns on. All of these issues started the day after I got a car audio system installed professionally. My car had no problems before the install. Ive looked up similar threads on here & other forums. No luck. Hoping someone has any ideas/solutions.
Old Aug 21, 2017 | 07:05 PM
i8acobra's Avatar
i8acobra
Did you get Nissan or other Japanese (Hitachi or Denso) sensors, or Chinese (Duralast, no-name eBay, etc...)? Nissans really dislike Chinese sensors. The other possibility is that the audio shop tapped into a wire they shouldn't have.
Old Aug 21, 2017 | 07:13 PM
CityOfSin's Avatar
CityOfSin
All 3 sensors are OEM man, im starting to think they messed up with the wiring because my car didnt have a problem before the install...
Old Aug 21, 2017 | 07:20 PM
i8acobra's Avatar
i8acobra
I have a shop here in Vegas, if you wanna bring it by. I won't charge just to look at it. PM me if you want my number.
Old Sep 7, 2017 | 03:35 PM
i8acobra's Avatar
i8acobra
Fixed!
Stereo shop
Old Sep 8, 2017 | 11:33 AM
zakmartin's Avatar
zakmartin
Did they hook a touchscreen HU to the wrong brake wire?
Old Sep 8, 2017 | 01:31 PM
i8acobra's Avatar
i8acobra
No. They broke the B2 cam sensor ground wire when the shoved the power cable through the harness grommet.
Old Sep 8, 2017 | 03:13 PM
zakmartin's Avatar
zakmartin
Oh, geez. Nice. Kudos to you for helping out a Z owner.
