Instrument Cluster problem
Old Aug 28, 2017 | 09:43 AM
Not my day's Avatar
Not my day
Default Instrument Cluster problem
Has anyone ever had this problem with the instrument cluster? It only happens on the odometer/tripometer. Do I need to replace the whole instrument cluster or is a loose connection somewhere. Also when I pull or push slightly on the cluster all of the digits come back normal which makes me think it's a loose connection.
ter side
instrument cluster
Old Aug 28, 2017 | 04:22 PM
dcains's Avatar
dcains
Take it apart and look for a bad solder joint. If you fix one, or can just reheat it until the solder flows and makes good contact again.
Old Aug 28, 2017 | 07:34 PM
Whiskers1996's Avatar
Whiskers1996
I had the same issue and I sent my gauges to be worked on @ gaugecraft by Bob. I can find the email/vids later, but what it came down to was replacing cluster bc of how/where it was damaged.
Old Aug 29, 2017 | 06:53 AM
iideadeyeii's Avatar
iideadeyeii
Looks like you diagnosed your own problem. Honestly though that would not bother me
