won't start
Old Aug 27, 2017 | 06:32 PM
inga's Avatar
inga
Default won't start
car started drove to gas station for a fill up it drove great as usual shut it off to go in and pay for gas went to start and it just clicked as if the battery was dead. had it jumped started right up went to pull out and the dash lite up' the lights that lite up on the dash were slip light' vdc off and brake' but didn't stay on when i'd accelerate it seemed as if it was braking for me and those lights would go off. i wasn't far from home and shut it off an went to restart and nothing no lights on dash and no crank. waited 10 min. tried again and dash lights and clicky noise then it cut power. put in new batattery and batteries in key fob and still same cycle. it has now locked me out but was able to solve that by disconnect of the negative battery cable, but still won't start
Old Aug 29, 2017 | 06:49 AM
Heel Til I Die's Avatar
Heel Til I Die
Your problem could be any number of things. If you google '350z vdc slip brake light' you'll find this comes up quite a lot.
It could be one or a couple of things: low brake fluid, bad ABS sensor, worn brake pads, short in a wiring harness, or bad cam position sensor.
The fact that those warning lights come on and based on your description that your vehicle brakes were engaging while you were accelerating, it sounds like your VDC is malfunctioning and applying the brakes because it "thinks" your losing traction.
The car not starting sounds like a different problem separate from the VDC - maybe CPS?
Have you changed anything recently? Tires? Wheel size?
Have you tried pulling the codes with a scanner?
Old Aug 29, 2017 | 11:59 AM
zakmartin's Avatar
zakmartin
Year? Mileage? Mods?
Mullen009
Aug 7, 2017 04:05 AM
Mullen009
Aug 5, 2017 10:40 PM
Realms
Jul 31, 2017 11:36 AM
