cam position sensor issue
Old Aug 31, 2017 | 03:16 AM
Zippyduda's Avatar
Zippyduda
Default cam position sensor issue
i have a 2007 nissan 350z. was getting on highway and the vehicle stumbled a little bit and then the idle started surging. have the code p0345 camshaft position sensor A CIRCUIT B2. i cant find any info on replacement and location. anything would help.
Old Aug 31, 2017 | 03:29 AM
travlee's Avatar
travlee
Master
passenger side (quick google search would have told you that), and another search would tell you the location. there isnt going to be alot of spoonfeeding here for ya.... do some research, then come back and ask questions if you have them still
Old Aug 31, 2017 | 02:29 PM
HOMiEZ's Avatar
HOMiEZ
youtube is your friend on this one. i just did it a few months ago.
Old Jan 10, 2018 | 08:54 PM
Zippyduda's Avatar
Zippyduda
ok. i have found out the info i needed. I have replaced both cam position sensors on the rear of the engine. That did nothing. So i was told by nissan tech that i could possible need to change the crank position sensor. So i also replaced that. and that still did nothing. i am not sure were to go from here. i checked the wireing over to make sure there were no breaks in the wires. the car barely idles and runs. Need help
Old Jan 11, 2018 | 01:33 AM
travlee's Avatar
travlee
Master
Quit throwing parts at it and take it to nissan for a proper diagnosis
PattyP
Jun 14, 2022 10:24 AM
shadowoffair
Jun 25, 2017 11:29 PM
Cux350z
Feb 9, 2016 04:54 PM
