350Z HR Brand new clutch slipping
Old Sep 24, 2017 | 08:39 PM
Kiz350HR's Avatar
Kiz350HR
Default 350Z HR Brand new clutch slipping
Alright so heres the story
>Installed new exedy ceramic clutch kit, solid flywheel, Zspeed billet csc.
>car skids 1st, 2nd but slips in 3rd
> sometimes slips 2nd if its hot
> have flushed and bled system multiple times using high temperature dot 4 fluid and heat wraped the braided lines (to eliminate the possibility of the cats boiling fluid)
has anyone ever had this problem? Thoughts?
Old Sep 25, 2017 | 04:59 AM
travlee's Avatar
travlee
Master
did you do the proper clutch break in?
Old Oct 4, 2017 | 06:51 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Did you buy the clutch and flywheel as an exedy package or buy them separately? Exedy's kits for the HR are only to be sold/used as a set, If you put and HR exedy clutch with a standard height replacement flywheel it will be WAY to high and cause partial clutch release and kill the clutch and slave fairly quick.
