Please help car still pulling to right
Old Feb 19, 2004 | 01:01 PM
Ghettorab's Avatar
Ghettorab
Default Please help car still pulling to right
Help, I just got my car serviced for pulling to the right, ive had the compression rod replaced and the 2 front tires and a 4 wheel alignment and the car still pulls to the right if anyone knows of anything else please inform me. Ive scoured the forums for any info im stumped please help.
Old Feb 19, 2004 | 09:44 PM
AmyCroft's Avatar
AmyCroft
Smile Pull to right
O.K.
My 350Z pulled to the right for the first 11 Months.
NNA replaced the two front RE040 18"s
The Dealer had a front only alignment done - not computerized - by hand... The first thing that is done is the Steering wheel is centered. Then a rope lashes down the steering wheel straight.
Then they read the toe in - ( only adjustment they can make in the front )
Left 1/4" to the right - right 1/4" to the right. ( humm that would make it pull to the right )
The alignment man then centered the toe in and added 1mm in bound each side. 2mm total .08" or .2 degrees.
The car with hands off runs straight even on a slightly crowned road.
I'll tell you more after I have a four wheel alignment done at Wheel Wherehouse in Anahiem.. Changing a few rear Camber Rods to ******* brand adjustable Camber rods.
Cheers Amy -
Old Feb 24, 2004 | 08:06 AM
misel00's Avatar
misel00
Default Re: Please help car still pulling to right
I'm going through tthe same thing with my 03 Z....three x's to dealer so far..2 alighnmenst done, one by a alighnment specialty shop! Pull to the right tsb done! rims and tires swapped out...and i only have 900 miles on ths piece of S%^t,,, IT STILL PULLS TO THE RIGHT AND DRIFTS ALLOVER...two service managers told me , they don't even know how to fixx the problem and have no clue what to do from here! NNA is useless!!!! So i just started my lemon law suit against nissan..I had enough !!! and the kicker!! after only 900 miles my tirees are starting to show the first signs of feathering,,,It'a suspension defect and it will never be right if you got " one" o fthes ethat pulls ot teh right...keep your paper work, and lemon law it!! other wise you will always be pisseed and the car will be nothing bu headaches !!! if you need any other info , just pm me, because for some reason e-mail notification is not working on my accoutn here!
etkms
Jun 19, 2022 06:30 PM
May 12, 2016 07:42 PM
Extreme Dimensions
Body Exterior
Nov 9, 2015 10:47 AM
RyansZ33
Sep 15, 2015 05:54 AM
