Fuel pressure on NA, should it drop with rpms?
Old May 7, 2018 | 04:11 AM
Artem_kiev's Avatar
Artem_kiev
Default Fuel pressure on NA, should it drop with rpms?
Hello everyone!
Does anyone have the fuel pressure gauge on NA car with stock fuel pump?
The reason I'm asking cause my fuel pressure gauge reads 51 psi at idle, as FSM suggests, but under hard acceleration it gradually drops to 42 psi or so near redline. The car is not FI anymore, fuel system is stock.
Also I've noticed that when I shut down the car fuel pressure slowly drops to maybe 40 psi or 35 overnight and gets back to norm when I start the car.
Are these things normal?
FSM check procedure says only 51 psi at idle and says nothing about the pressure under acceleration.
Old May 7, 2018 | 02:33 PM
karlt's Avatar
karlt
I would say your readings are normal. The fuel pump runs at constant speed, and has a built-in pressure regulator, so the pump is trying to output a constant flow at a constant pressure. At idle the engine is using the least amount of fuel, so the fuel flow into the engine is at its minimum. As rpm increases, so does fuel flow through the injectors. This increased flow rate causes the decrease in pressure your gauge measures.
Old May 8, 2018 | 01:19 AM
Artem_kiev's Avatar
Artem_kiev
Thanks for the answer, got your point.
350DTX
Mar 25, 2014 07:28 AM
ranmas2004
Jul 14, 2012 08:01 PM
dakota9812
Drag
Oct 5, 2009 01:23 PM
kevinapex
Feb 22, 2007 05:50 AM
FuzzyThread
Aug 19, 2004 06:13 PM
