Engine Bay Restoration Help
Old May 28, 2018 | 11:09 AM
Bernardo Z33's Avatar
Bernardo Z33
Default Engine Bay Restoration Help
Hello everyone! I am trying to tighten up my engine bay and make it all look oem and function right. I bought a lot of the plastic clips/battery cover that was missing. There are just some small things that are missing or that are out of place and I need your guys help. There is a ground cable that is not connected to anything and two screws that are missing on top of the plenum. I'm also missing the rubber flap that is clipped next to the battery plastic and also a little grommet by the door handle. If any of you guys could link me to these parts would be greatly appreciated! A big thanks to everyone that helps! (In the pics im pointing at the things that I need help finding or that are missing)
Attached Thumbnails Engine Bay Restoration Help-20180527_125345.jpg   Engine Bay Restoration Help-20180527_125356.jpg   Engine Bay Restoration Help-20180527_125405.jpg   Engine Bay Restoration Help-20180527_125425.jpg   Engine Bay Restoration Help-20180527_125452.jpg
Old Jun 8, 2018 | 07:34 AM
munkeymike's Avatar
munkeymike
Go to your local junkyard. All of this will cost just a few bucks and you will get exactly the parts you need. Just make sure the engine models are the same.
Old Jun 8, 2018 | 10:04 AM
SpartaEvolution's Avatar
SpartaEvolution
I think the two missing bolts on the top of the intake plenum are for the engine cover. I believe the ground strap should also attach to the plenum but I can't really tell where from the orientation of the picture. As munkeymike said, your best bet is going to be finding another Z to inspect and see what/where everything is supposed to go, or going to a junkyard that has a Z.
uzclutch23
Jun 19, 2016 08:00 PM
