Changed Valve Cover Gasket and Spark plugs now rough idling
Old Oct 10, 2018 | 08:59 AM
PandaPillowPet's Avatar
PandaPillowPet
Default Changed Valve Cover Gasket and Spark plugs now rough idling
Hey guys so last weekend I started checking spark plugs since I was getting some SLIGHT misfire and low and behold it was time for some maintenance on the car. I did see some oil leaking on the passenger side of the car so I went ahead and bought the gasket to replace. I was able to put it all back except I snapped a bold on the Valve cover and put some RTV to cover it while I waited for a kit to pull the broken bolt. Put it all back and when I went to fire the engine I got the p0300 (multiple misfire) I may have mixed up the coil pack wiring on the passenger side of the car. Checked online for the wiring and I still feel it could be off. Other than that Im not sure whats wrong and causing it to misfire that much. Really need this car ready by next week as I have a road trip. A week of researching and still cant find anything that would help. Appreciate the replys
2004 Nissan 350z
Old Oct 15, 2018 | 07:11 PM
ericshins's Avatar
ericshins
Is it possible you switched up the 3 and 5 coil wires like you've mentioned? Have you tried unplugging each coil while running and listening to see if the engine note changes? Could be a bad coil as well.
Sleeper_Z
Apr 28, 2016 09:21 PM
R&DFactory
Oct 23, 2014 06:03 PM
mcarther101
Sep 23, 2013 05:34 AM
sinasajadi
Jul 18, 2010 07:33 PM
baileyrx
Feb 26, 2006 07:13 PM
