Window goes down but not up
Old Oct 26, 2018 | 11:47 AM
Duangsima's Avatar
Duangsima
Default Window goes down but not up
On my 2003 350z I have a problem where the window won't go back up once it goes all the way down. It will go up if I put down half way but once it reaches the bottom it wont go up. I have replaced the motor and regulator. The motor works by itself as I tested that it does rotate both ways. Also there is the same problem if intake the window out of the car and just use the motor to move the regulator. It doesnt go up when it reaches the bottom. I feel as if the motor loses power or doesnt have enough once it reaches the bottom. Any suggestion or does anyone have a similar problem?
Old Oct 26, 2018 | 12:01 PM
iideadeyeii's Avatar
iideadeyeii
Window reset/relearn procedure
Old Oct 26, 2018 | 12:09 PM
Duangsima's Avatar
Duangsima
I haven't tried that yet. Will give it a shot
Old Oct 29, 2018 | 03:37 AM
travlee's Avatar
travlee
Master
aka basic troubleshooting 101
Old Dec 6, 2018 | 01:22 PM
EFCR's Avatar
EFCR
Default Problems with driver windows
When I open the door thw window motor not sound and not going down. if I push down the window the motor start to work. If I close the door the window work perfectly but if I open again it stops to work.
I have tried to calibrate via switches, I reset the motor as I read here and nothing happen.
Comments and help.
Thankyou so much!!
Regards from Costa Rica (PURA VIDA)!!!
Old Dec 6, 2018 | 04:29 PM
Chihuahuamaster's Avatar
Chihuahuamaster
Comments and help.
Thankyou so much!!
If you did the reset procedure correctly, the window should move down when opening the door, and come back up, when closing the door.
How does the window motor sound when it works? If it sounds like it is 'struggling,' low pitched whining sound, then I'd say your window motor needs to be replaced.
KuNGF00Chris
Apr 4, 2016 04:31 PM
black03350z
Jun 8, 2010 07:04 PM
sicilianoNYC
Jul 4, 2006 06:53 AM
DMONTE
Sep 24, 2003 08:59 PM
