Rear differential bushing tool
Old Apr 1, 2019 | 12:20 AM
WhiteTreeFiddy's Avatar
WhiteTreeFiddy
Default Rear differential bushing tool
Hey all,
Just bought my first Z car a couple weeks ago, it has the dreaded leaking diff bushing. I was doing alot of searching on this forum and stumbled across a post regarding a free to borrow rear bushing removal tool. The last post I saw on the thread was from a guy in GA asking to borrow it. I've looked and looked and searched but have not been able to find the thread again. Could someone one post a link to it?
Thanks!
Old Apr 1, 2019 | 03:56 AM
travlee's Avatar
travlee
Master
https://www.z1motorsports.com/advanc...s=Bushing+tool
Old Apr 1, 2019 | 05:00 AM
WhiteTreeFiddy
Thank you for your reply, but I think you misunderstood my post. There is a loaner one on the forum I was trying to locate.
Old Apr 1, 2019 | 05:15 AM
travlee's Avatar
travlee
Master
i understood your post, just buy the dang thing...
Old Apr 1, 2019 | 05:30 AM
Cracka350's Avatar
Cracka350
Yup, buy it and then put it on ebay when you're done. It'll save time searching.
Old Apr 1, 2019 | 06:59 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Good idea. Or, put it up on the my350Z Marketplace. Someone doing their diff bushing (and someone always is... ) will buy it. [Rinse and repeat]
Old Apr 1, 2019 | 07:07 AM
travlee's Avatar
travlee
Master
new members seem to always want something for free.
Old Apr 1, 2019 | 12:32 PM
coletrickle74's Avatar
coletrickle74
Just buy a sawzall instead of the tool. You'll get more uses out of it.
Old Apr 2, 2019 | 01:21 AM
WhiteTreeFiddy
Okay then I guess you can't read. No where in my post did I say I'm looking to buy one. A member bought one and was kind enough to loan it out. Being that its a tool I'll only use once, I would be better of just borrowing it and then shipping it to the next member that may need it. I have a sawzall so I will use it if I couldn't locate the loaner thread. So keep your useless two cents to yourself travlee.
Old Apr 2, 2019 | 01:28 AM
travlee's Avatar
travlee
Master
Awwww, not only is someone a cheap ***, they also got butthurt
Old Apr 2, 2019 | 01:50 AM
WhiteTreeFiddy
lol i'm not butthurt, everything you say is irrelevant..sooooo keep typing keyboard gangster
Old Apr 2, 2019 | 02:17 AM
travlee's Avatar
travlee
Master
uh huh.... just buy the damn tool and then sell it when you are done.
Old Apr 2, 2019 | 02:38 AM
WhiteTreeFiddy
That's the plan, have a good one
Old Apr 2, 2019 | 06:40 AM
g356sp's Avatar
g356sp
Don't worry OP, I'm a cheapskate too, and I was able to do it with a cheap set of harbor freight chisels, and decent cordless drill / sawzall (though you could use the cheap HF versions of those too).
So if you can't find the tool, you still have cheap options.
Old Apr 2, 2019 | 07:28 AM
WhiteTreeFiddy
Thanks for your reply, i believe I'm going to do the good ol' sawzall method, I was just worried about damaging the subframe where the bushing goes, but I'll just have to be extra careful lol I mean the front diff bushings can be knocked out with a socket.
Old Apr 2, 2019 | 07:40 AM
g356sp's Avatar
g356sp
Best to have some mid-grit (1-200) sand paper handy as well, I did a decent amount of scuffing-up on the subframe, but it sanded back out pretty easily.
Old Apr 2, 2019 | 07:45 AM
WhiteTreeFiddy
Good thinking! I plan on doing it tomorrow. Throwing the bushings in the freezer now
Old Apr 2, 2019 | 07:52 AM
travlee's Avatar
travlee
Master
a hole saw, like for a door comes in handy too, i cut out the middle of the diff bushing with tht.... if you use the sawzall... score the outer metal of the oe bushing some, then get a point punch (or chisel) to knock it up... it will eventually taco at that crease
are you planning on doing the diff ear bushings as well?
Old Apr 2, 2019 | 11:39 AM
WhiteTreeFiddy
Good thinking! The hole saw hadn't crossed my mind but it makes sense. I will give it a shot, I guess I was just being paranoid about messing up the subframe and not being able to get the bushing in. Yep, I bought the entire kit from Z1, so diff ears will be done. Thanks for the advice!
Old Apr 2, 2019 | 03:27 PM
travlee's Avatar
travlee
Master
See....I am not always a dick
Just most of the time
