Error Code: P0340 Camshaft bank 1
Old Aug 23, 2019 | 01:12 PM
ivan_cebreros's Avatar
ivan_cebreros
Default Error Code: P0340 Camshaft bank 1
Hello,
My nissan 350z 2004 with 154,000milles already makes a crank when i want to start the car, and now it turn on the SES(service engine soon) and the TCS and SLIP lights,
so i put a reader code and send me only the code to P0340 Camshaft bank 1, this is the passanger side so y buy it on Ebay cause its cheaper.. the model that i buy was 23731-6J90B, now a change it, it works fine only the night and none lights turn on. In the morning i turn on the car at first it didnt show nothing, when i put reverse that turn off and won't started.
So i go and bought a new sensor on autozone and installed and make the same problem, at night works fine but after a day its the same issue, i reset the codes from the reader machine, after trying to turn on, the SES light turn on and its the same problem !
the camshaft sensor that it haved or model was an Hitachi: A29-640-C20 and that i bought on Ebay in the first place was an A29-640-C23. maybe thats the problem? in the Autozone dont says any number. i put the VIN number on parts nissan page and says that part number: 23731-6J906 is replaced by: 23731-6J90D
So what can i do??
Thanks.
Old Aug 24, 2019 | 08:25 AM
jellofuel's Avatar
jellofuel
The issue's your sensor. You need oem quality and checking autozone's site, the passenger side sensor's part number is CPS0002.
Looking at Z1's site, Nissan sells a revised version of the sensor - https://www.z1motorsports.com/crank-...er-p-4093.html
Old Aug 24, 2019 | 02:43 PM
ivan_cebreros
Hello, thanks for the reply.
I will change the sensor to one used from my friend's hope to see if it works well, i will buy it to the page recommended or even on nissan autoparts website.
the Autozone model is SU6516 is more expensive that Hitachi CPS0002. recommend to buy Hitachi?
Something that a read on reddit thread was that maybe is too the harness, maybe its the main problem. cause change with two sensor and none of them works, hope the third do.
Mikegconigs
Dec 8, 2017 07:40 PM
SDbackstock
Feb 3, 2010 08:34 PM
banshee
Oct 4, 2009 07:30 AM
jvargas714
Sep 15, 2008 10:25 AM
