Cam shaft sensor plug broken
Old Jan 12, 2020 | 01:14 PM
SWOK561's Avatar
SWOK561
Default Cam shaft sensor plug broken
So my friend and I were changing out the cam sensors in the Z got the driver side done and he did the passenger side. Well after he got the 10mm off he was having trouble taking off the plug and doing so he broke a part of the plug. We tried to tighten it back up and we got the cam sensor code.
My question is 1. Is there a way we can get a new plug and just take the wires out of the old one ? I do t know how to do that if it is possible.
Do we have to buy another plug harness and splice the wires and then put them together ?
Thanks for the help
Old Jan 12, 2020 | 01:29 PM
bealljk's Avatar
bealljk
Yea - you can de-pin a camshaft position sensor plug. They are a little harder than normal plugs (found around the car) but it can be done. Your smarter move will be to purchase a new plug with a pig-tail wires and just splice it into the OEM wires.
Also, the passenger side and driver side plugs are different - so a drivers side plug will not work in the passenger side.
Old Jan 12, 2020 | 02:30 PM
rustyschopshop's Avatar
rustyschopshop
Got both of my replacements from wiring specialties. Would recommend sodder and heat shrink for the splicing.
Old Jan 13, 2020 | 12:31 PM
tcode's Avatar
tcode
If it helps you can use and probably much easier to find, a plug from the steering servo pump pressure switch. Don't ask me how I know .
Old Jan 13, 2020 | 01:42 PM
bealljk's Avatar
bealljk
yeah - how do you know that?
I bought a new pig-tail plug/connector for like $20 off ebay …
Old Jan 13, 2020 | 01:55 PM
tcode's Avatar
tcode
Mine broke too and was in a hurry to fix it. Looked everywhere and couldn't find any in a such a short time. I was desperate and helplessly sitting in a front of the car when suddenly steering servo pump pressure switch catches my eyes. Although it has a different clipping system, it perfectly fits to the camshaft sensor. Bonus, it is much easier to plug/unplug it than original camshaft sensor. Man, I was so happy .
On Ali those are quite cheap:
https://www.aliexpress.com/item/4000...chweb201603_53
Remix2186
Apr 9, 2018 04:37 PM
Invinceable
Mar 26, 2014 05:53 PM
narkotic
Apr 27, 2013 04:13 PM
bbs350z
Oct 11, 2010 07:51 PM
590sxz
Feb 25, 2009 05:45 PM
