Replica cps sensors
Old Feb 9, 2020 | 08:53 AM
Supermotogoon's Avatar
Supermotogoon
Default Replica cps sensors
So basically Im in the middle of swapping in a complete 50k mile vq into the Z. I bought the 3 sensors that are usually a pain to but didnt realize they where reps (made in china) does anyone have experience with these? When did your stocks go out?
Old Feb 9, 2020 | 09:14 AM
jhc's Avatar
jhc
General & Tech Moderator
Since you don't state WHICH sensors I'll presume you mean 2 cams and 1 crank. General opinion here is oem only, apparently the Nissan electronics are finicky. My sensors are all original at 108K with 0 problems. OEMs I believe are Hitachi or mb Denso (fka Nippondenso).
Since you've spent the money I'd do this-
See what happens with the ones the motor came with. If codes or no start then
Put in generics as needed. If codes or no start then
Get OEMs from a respectable source.
gl!
Old Feb 9, 2020 | 11:27 AM
Supermotogoon
Thanks for the input
Old Feb 9, 2020 | 12:27 PM
rustyschopshop's Avatar
rustyschopshop
Since you are swapping engines, if needed use the sensors off the original engine if needed. When i swapped my engine recently 1 sensor on the donor engine was broken and use my original to replace it with.
Austin Brown
Jul 24, 2019 07:11 AM
titanjc
Jul 14, 2006 07:16 PM
cyberz350
Mar 1, 2006 10:04 PM
