AC Issue only hot air
Old Jun 4, 2020 | 09:05 AM
RiggZie's Avatar
RiggZie
Default AC Issue only hot air
Hello, 2004 350z track edition so I'm running into an issue today where I started my car and turned on my AC to the coldest setting and blasted it because it's really hot out (NJ 88 degrees). After about 10-15 minutes as I was sweating I realized it was not getting any colder. My car was not overheating at all but I noticed both radiator fans are not working. I know it is full of R134. Any help would be appreciated as I normally dont muck with AC but it's too damn hot to not have AC.
Old Jun 4, 2020 | 09:16 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Sorry- you're going to have to muck with it if you want any a/c. The HVAC systems on Z33s are usually very robust, so start by checking the FSM for troubleshooting the system. There's no magic bullet to give you, and it could be a relay failure or other problem that you may need a pro to trace down.
Old Jun 4, 2020 | 12:36 PM
calvin.w's Avatar
calvin.w
Better pray you don't have my problem:
https://my350z.com/forum/maintenance...c-problem.html
I still don't have ac! My last resort is right in front of my face, replacing the IPDM
Old Jun 5, 2020 | 01:57 PM
RiggZie's Avatar
RiggZie
its all good had to replace AC fuse bow I get cold air
FLAMADSCIENTIST
May 24, 2012 01:19 PM
III
Apr 18, 2008 11:18 AM
gt3
May 24, 2007 09:23 AM
Conceyted
Sep 20, 2006 06:20 PM
