Overheating blowing my mind. ​​​​​​​
Old Apr 22, 2021 | 09:41 AM
maxh1324's Avatar
maxh1324
Originally Posted by Jim Stephens
Yes on possibly the head gasket. Did you run that test you can get from Amazon to see if there is carbon dioxide in the radiator fluid?
https://www.amazon.com/Block-Tester-...9040969&sr=8-5
This last time, it took me three tries to get the radiator completely clear of air bubbles. Random over heating in fast food lines. I did though, eventually discover the REAL reason it was a problem for me this time around. There was a tiny leak in one of my radiator hoses and over time I was loosing fluid and of course air was being introduced into the system. The way I found it is was to use this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
So, you pressurize the radiator cooling system, grab a light and take the shroud off the bottom and start looking for fluid. Actually, by the time I jacked the car up, put in some more fluid and took off the bottom shroud I easily spotted it. Here it is, the yellow hose that was clear of the A/C flywheel, but was flexing under load and slowly a pin hole was created. I had used this hose for 9 months before it failed, so never even considered that my problem would be a leak. I went back to a Rigid black OEM hose to solve it permanently.
Like everyone else has already stated Jack the front up super high, put this funnel on and run it up and down with the heater on at all times. I set the timer on my phone and go a minimum of 30 minutes. A fair amount at 3k rpm as it says in the manual.
https://www.amazon.com/Kauplus-Radia...xpY2s9dHJ1ZQ==
I'm starting to believe it may be a tiny coolant leak that leaks right onto the engine and burn away before it is noticeable, there are times i can smell coolant, which is making me thing that. Need to get some time to assess all the hoses and have the car not running for a few days to tear stuff apart, thanks!
zprz
Dec 2, 2015 12:56 PM
Moe747
Jul 17, 2015 09:06 PM
2alien10p
Mar 9, 2015 01:47 PM
dfresh713
Aug 6, 2009 12:32 PM
imseksy
Sep 20, 2008 10:22 AM
