No set light/ cruise control not working
Old Apr 17, 2021 | 11:03 AM
Momz's Avatar
Momz
Default No set light/ cruise control not working
I've got a 2005 350z enthusiast edition. Right now none of the cruise control lights on the dash will come on when I press on/off and set. They were working fine before I installed an aftermarket head unit, pulled the transmission for the clutch and replaced the wheel bearings. So far I've checked all the fuses, adjusted the cancel switch on the clutch, made sure the ground cable was clean and tight and reinstalled the old wheel bearing. Still nothing. I've also noticed they lights don't come on the dash when the ignition to on. Not sure what else would cause this. Any other possibilities that would cause this such as clock spring or dash or something?
Djnaz
May 23, 2022 04:59 AM
SFerg
Apr 5, 2018 07:48 AM
Hunter Greene
Jan 20, 2017 06:41 PM
shadowoffair
Oct 18, 2016 12:00 PM
