Compression arm tightening help
Old Sep 26, 2021 | 07:18 PM
Dtoodlez's Avatar
Dtoodlez
Default Compression arm tightening help
My 350z compression arm won't tighten it just keeps free spinning. I Don't think the ball joint itself is broken because the owner before me just replaced it. Anyone have had this problem before and have found a solution? thanks in advance
Old Sep 27, 2021 | 04:27 PM
Ponyryd's Avatar
Ponyryd
The stud will be a taper fit, you’ll need to apply some load to it by prying it into its hole, the tightening.
Old Nov 21, 2021 | 05:52 AM
novaboll's Avatar
novaboll
I used tape measure around my arm to see what the recommended size was, the sleeve should show you what arm size equates to S/M/L on the listing. It should not be cutting off blood flow, it should be just a bit snug on your arm so it
doesn't flop around or slide off.
Bak3rme
Apr 12, 2016 03:37 PM
GarniZ33
Jul 7, 2015 07:31 AM
lsxjunkie
May 25, 2013 09:36 PM
Shawz1102
Nov 12, 2011 12:41 AM
dragonfire6
Oct 19, 2009 05:54 AM
