Complete Loss of Power
Old Nov 8, 2021 | 07:20 AM
JakeGetCake's Avatar
JakeGetCake
Exclamation Complete Loss of Power
I was driving one day (not even spirited) and the CEL, TCS, and Slip light all came on at once. The gas pedal wasn't doing jack ****. So I pulled over and gave her a good restart and now just the CEL is on. From reading I figured it was a crank or cam shaft. I took her to the dealership today and they wanted $160 just for a diagnosis. I left immediately and went to the AutoZone that is less than a mile away to get it scanned for free. Came up with code p2135 which has nothing to do with cam or crank shaft sensors. This problem appears to be throttle body or throttle actuator. I don't think it's my TB because I just put in a brand new CZP 75 mm throttle body. Most people say to forget this code and clear it, but if it comes back get it looked at. What's my best option here? If I wanted to clear it without a scanner can't I just disconnect and reconnect the battery? Thank y'all
Old Nov 9, 2021 | 08:37 AM
Marcus_spagetti's Avatar
Marcus_spagetti
i got this same exact problem i replaced both sensors already and still not working I am going to replace flywheel and see how it goes but if you find something out please let me know.
Old Nov 16, 2021 | 08:11 AM
drozzy's Avatar
drozzy
You, as in you yourself installed the 75mm TB recently? Full tune... or not?
If no tune, you were just asking for trouble / no enough research. Using the 75mm TB you'll get issues, usually idle related though, if you don't adjust the AFR down low in the RPM range. My DE ran like absolute crap the day it was installed, all of 6 minutes of **** driving to get to the tuner. Then post-tune that was solved, smooth idle & no lights on the dash. Remove the WOT limitation from the ECU when you get the tune, then have fun with the difference it will make off-the-line.
kart14
Oct 3, 2016 12:54 PM
debsib
Sep 9, 2014 03:52 PM
johnnyzcar
Oct 10, 2013 06:31 AM
RKnight
Nov 28, 2010 01:38 AM
chromesilverz
Aug 12, 2008 03:56 PM
