B&M 70266 Automatic Transmission supercooler help
Old Dec 18, 2021 | 05:40 PM
08HR350Z's Avatar
08HR350Z
Default B&M 70266 Automatic Transmission supercooler help
Hi there I bought a B&M 70266 Automatic Transmission cooler 20,500 BTU and don't know what size hoses to use and what brackets, zipties etc I need for install? Im struggling and have been searching for hours what size hoses I need for the cooler and if I should use braided lines and what size, what kind and 6AN? 8AN? 10AN. It says it comes with 1/2 NPT inlet/outlet but thats it. I
Heres the cooler selection chart on back of the box thanks
can only see anything about 6AN please help as Im at a standstill on what hose size and clamps are needed and if I should pay extra for braided lines? Thank you in advance
Old Dec 18, 2021 | 07:02 PM
AxionZ's Avatar
AxionZ
I don't know what size hoses you need, but you can measure the OD of the old provisions from the transmission side. Then find the appropriate size and length lines, it may be 6an. The fitting thread on the cooler is 1/2 NPT so going to have to get 1/2 NPT to 6an or barb fittings. I'm sure someone has done something similar on here. As for the bracket you will have to make your own. You can make simple brackets and then use these
mounting zips mounting zips
normally used to mount the fan, to mount the cooler to your bracketry since this one doesn't have a decent mounting solution.
Old Dec 22, 2021 | 07:53 AM
08HR350Z's Avatar
08HR350Z
Originally Posted by AxionZ
I don't know what size hoses you need, but you can measure the OD of the old provisions from the transmission side. Then find the appropriate size and length lines, it may be 6an. The fitting thread on the cooler is 1/2 NPT so going to have to get 1/2 NPT to 6an or barb fittings. I'm sure someone has done something similar on here. As for the bracket you will have to make your own. You can make simple brackets and then use these mounting zips normally used to mount the fan, to mount the cooler to your bracketry since this one doesn't have a decent mounting solution.
Thanks I bought the b&m mount kit and hayden mount kit with brackets but reading online I see 6an is mostly 3/8 and 8an has 1/2 fittings but I still haven't figured it out nobody has helped me on here besides the little info from you. I hope someone can help me find the fittings needed I was going to get 6ft 8an ptfe teflon lined braided line from summit racing but can't figure what fittings are needed?
Old Dec 22, 2021 | 08:30 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Best bet: Call Holley @ 1-866-464-6553 for tech advice.
Old Dec 22, 2021 | 08:32 AM
AxionZ's Avatar
AxionZ
Get two of both the items below and how ever long 6an line you need. Use plumbers tape on the npt, don't forget hose clamps.
https://www.summitracing.com/parts/e...xoCS5MQAvD_BwE
https://www.summitracing.com/parts/msd-2935
Old Dec 22, 2021 | 08:35 AM
AxionZ's Avatar
AxionZ
Or get this, comes with everything.
https://www.z1motorsports.com/transm...RoC_REQAvD_BwE
Old Dec 26, 2021 | 09:24 AM
jhc's Avatar
jhc
General & Tech Moderator
And avoid zip-ties. There only good for test - fitting.
Old Jan 5, 2022 | 08:24 AM
08HR350Z's Avatar
08HR350Z
Thank you and I got a 6ft braided summit 8an ptfe hoses and the outlet on the B&M cooler is 1/2 NPT so I got 8an to 1/2 NPT fittings 2 of em. I won't be using hose clamps because I got braided line so I didn't have to worry about the clamp failing while driving in the summer. Its like 120°F here in the summer so I need it to work really good without failing. Thanks for your help and the 2nd link 350 for a cooler is insane I got the 20,500 BTU B&M which is like one of the best for only 130 the hoses and clamps was what was expensive 40 bucks for one hose. Thanks again for the help
Old Jan 5, 2022 | 08:30 AM
08HR350Z's Avatar
08HR350Z
Well I bought 2 kits because I returned the B&M 70264 kit with 14,500 BTU for the 70266 20,500 BTU which doesn't have install kit with it because it can be used for differential fluid or engine or trans so they consider it custom. I bought the B&M ziptie install kit and Hayden automotive install kit with brackets and stuff so don't use zipties whats wrong with the circle zipties in the install kit? It's B&M 80278 install kit only came with zipties. I'm not sure now seeing as the universal cooler 70266 I got has the low pressure drop feature to make sure it doesn't overcool the transmission. Thanks
Old Jan 9, 2022 | 07:32 AM
jhc's Avatar
jhc
Originally Posted by 08HR350Z
Well I bought 2 kits because zi returned the B&M 70264 kit with 14,500 BTU for the 70266 20,500 BTU which doesn't have install kit with it because it can be used for differential fluid or engine or trans so they consider it custom. I bought the B&M ziptie install kit and Hayden automotive install kit with brackets and stuff so don't use zipties whats wrong with the circle zipties in the install kit? It's B&M 80278 install kit only came with zipties. I'm not sure now seeing as the universal cooler 70266 I got has the low pressure drop feature to make sure it doesn't overcool the transmission. Thanks
Ok, I kinda get it- if all 4 corners are secure and there's no danger of sharp metal edges slowly knifing through vinyl then you should be good. Always just seemed like a half-azz temporary method to me (as opposed to real brackets). No worries.
Old Jan 9, 2022 | 09:20 AM
08HR350Z's Avatar
08HR350Z
I'm seriously struggling he installed it so he cut the 6ft braided line in half to expose the teflon tubing and installed it onto the stock transmission lines one on the in and one on the out and use fuel line clamps but leaked so I had him install put the oem lines back up. Im not sure where to go from here. Can you help me out please?
Old Jan 11, 2022 | 07:40 AM
jhc's Avatar
jhc
Without pics I'm not certain I understand the issue. The OEM lines are only long enough to reach the radiator. Please post a couple pics and clarify exactly what you need help with.
I'll ask a friend to help. @bealljk
Old Mar 21, 2022 | 09:19 AM
JeanFolden's Avatar
JeanFolden
Hello guys, I need B&M 70266 automatic transmission super cooler help and for that, I am searching for it online. I am glad I have found your post. Now, I can repair it on my own. Thanks all for your suggestions. Can you guys also give me suggestions on this https://writinguniverse.com/free-ess.../just-society/ site? Because I want to take help from that website to complete my essay assignment and before that I want to know about that website.
Chad68
Dec 30, 2006 04:27 PM
timdawg
Jan 26, 2005 06:03 PM
maserom
May 12, 2003 09:21 AM
