Why do I have these O2 ECU codes!?
Old Jun 11, 2022 | 08:12 AM
350zTotal's Avatar
350zTotal
Default Why do I have these O2 ECU codes!?
I've replaced all 4 O2 sensors and reset ECU several times.
Car is not tuned.
No engine modsStock cats+downpipesTomei exhaust
'07 350z
Old Jun 15, 2022 | 05:30 AM
Heel Til I Die's Avatar
Heel Til I Die
If all 4 sensors are good, then some other possible causes are the harnesses or connectors, fuel pressure, fuel injectors, or intake air leaks. Easiest thing would be to check for any shorts or breaks in the wiring or harnesses.
Old Jun 22, 2022 | 09:15 AM
350zTotal's Avatar
350zTotal
Do the sensors look good based on my obd reader info?
The fuel trim is higher on one bank but I read that's normal. Doubt it's a fuel pressure issue if fuel trim is still happening.
What should I do?
Xonatron
Apr 20, 2015 04:27 PM
Gman2004
Apr 22, 2006 06:47 PM
toykilla
Dec 3, 2003 09:47 AM
