Cylinder 3 Misifire - Electrical problem?
Old Aug 15, 2022 | 07:30 PM
Blue350Z2003's Avatar
Blue350Z2003
Default Cylinder 3 Misifire - Electrical problem?
Hey there, currently I'm having a misfire in cylinder 3.
My 2003 350z was running absolutely fine, took it out for a quick drive one day and let it sit for a few hours when I started it back up again it instantly started misfiring and the engine shut off while I was driving about 10 seconds down the road. The misfire then went away for a day and came back, now it is constant and occasionally the engine will shut off when warm.
Both myself and the mechanic have been checking it over. Coil packs and sparkplugs are confirmed working. I decided to test my injectors and they are also working, however, I also decided to test my wiring/voltage at the coil packs and injectors.
Everything checks out apart from the injector 3 wire that connects to the ECU which is currently measuring no voltage whereas the other 5 injector wires connected to the ECU are measuring about 12 volts. I believe this is where my problem is, I've done a continuity test on the injector 3 wire and the wire is allgood. Its not reading any voltage at the injector 3 ECU pin.
I'm really lost here and need some help trying to figure this one out, could it be a relay? could bad ECU ground affect this? is my ECU toast? a fuse? going to get the ECU tested soon but just thought someone might have some insight.
Thanks heaps for any help!
jowjeh
Aug 28, 2022 07:54 AM
NOSDEVIL
Aug 18, 2016 02:40 PM
rocks
Nov 28, 2014 11:33 AM
spent
Feb 23, 2011 08:06 AM
617G
Dec 24, 2007 06:29 AM
