2005 Interior & Exterior Electrical Issues
Old Sep 14, 2023 | 07:16 PM
Kylyos's Avatar
Kylyos
Default 2005 Interior & Exterior Electrical Issues
2005 Touring Auto.
Observed Anomalies
Previous owner clearly had modifications they had taken out (Screw holes found between backside center console, Push start engine FOB given with car but no reaction from FOB to Car, Aftermarket wire connectors found in engine bay and front bumper)
Passenger headlight and radio harness was found horribly spliced (Passenger Low beam had H7 connection inserted and functional, Highbeam OEM H7 connection still in place but not functional)
Exterior Issues
Side Mirrors not adjusting with switch
OBD scan done 10 BCM codes (most relating to tire sensor)
C1705
C1711
C1709
C1727
C1707
C1706
C1708
C1726
C1729
C1710
Fuses checked all seem to be operational no missing fuses.
Interior issues.
Cluster Lights out
Radio non functional, no power received through 12 V Switched wire but power believed to be receiving through 12 V Constant wire, mystery ground cable found screwed between M60 (A/C sub-harness) and M35 (Display unit)
Driver Airbags Codes
B1049 [Open]
B1054 [Open]
Trip meter code
B2201
CAN code
U1000
Conclusion
Bad BCM and terrible previous owner?
I need some suggestions.
S.O.S ,
Kylyos
Old Sep 15, 2023 | 04:11 AM
travlee's Avatar
travlee
Master
sounds like you bought someone else's headache
Old Sep 15, 2023 | 09:45 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Depending on where the splices are in the harness, you may need to replace the entire engine and one or both of the interior harnesses. I hope you bought this Z for a song, because it may take a symphony to repair it.
Aj_
Jun 15, 2023 07:55 AM
Macanic
Jan 11, 2022 02:49 PM
Heritage
Mar 15, 2020 09:38 PM
wygonski
Sep 13, 2019 01:39 PM
cashmoney03
Jul 14, 2015 06:38 PM
