Still no AC on 2005 Z
Old Dec 8, 2021 | 09:56 AM
Macanic's Avatar
Macanic
Default Still no AC on 2005 Z
Checking voltages at ECM. Looking for wire or wires in harness for supply to high pressure sensor under hood a right Headlight. Color and volts with switch on, full charge,.
my diagram shows b/w ground, b/y 5v power supply,, W--1.0-4.0. This is a 2006 revision, would colors have been different before revision? Stumped is the word of the day.
Old Dec 8, 2021 | 11:06 AM
travlee's Avatar
travlee
Master
did you check the ribbon cable behind the controls?
Old Dec 8, 2021 | 11:08 AM
Macanic's Avatar
Macanic
I did. Looking at BCM at the moment.
Old Dec 10, 2021 | 09:43 PM
Tomek350Z's Avatar
Tomek350Z
have you tried jumping the relay on the AC coil to see if it engages when the engine is running?
Old Dec 13, 2021 | 11:06 AM
Macanic's Avatar
Macanic
You can jump the coil at the PDM, L/Y wire and it engages fine,
Old Jan 11, 2022 | 02:26 PM
Tomek350Z's Avatar
Tomek350Z
so when you jump the compressor relay, the A/C system does not cool the vehicle? What temp is coming out of the vents with the compressor jumped for like 4 minutes?
Is the AC button orange light blinking when trying to activate?
Any DTC's?
Old Jan 11, 2022 | 02:49 PM
Ponyryd's Avatar
Ponyryd
Most likely you have a low system charge so I’m not sure I’d be cycling the compressor too long. If you can access the valve, give it a little push with a small screwdriver to check the pressure in the system…at static (not working) it should be around 90-100 psi, so there should be significant pressure there (keep face away). Less pressure means you’re gonna be headed to a shop for the repair.
Otherwise you may have a sensor issue and I’m not sure what kind of sensors they use in these, but what I usually do to test is take the plug off and short it together if it’s a 2-wire sensor. If everything works then you’ve found your problem.
Macanic
Nov 15, 2021 04:01 AM
chodalak
Jun 28, 2011 11:15 PM
350niZmo
Oct 16, 2010 11:46 AM
AUtigers350z
Sep 19, 2009 06:22 AM
