Nissan Elgrand VQ35DE
Old Sep 28, 2023 | 05:39 AM
Richma's Avatar
Richma
Unhappy Nissan Elgrand VQ35DE
Hello guys. First i want to say sorry if my english is bad, this bcoz this language is not my main.
So here is story. Once before one of my customer come with this car with problem about no rev power. when i attached to obd scanner it was said that the problem is in camshaft pos. sensor (p0340). I buy new and change, still the same problem, okey. Some guys was telling me the problem is in the timing chain, i change it and its perfect. Still the same. Then i found a post where a lot of guys said that maybe the problem is in oil gallery (behind the chain), i buy new gasket and i change it. Still same. I change the oil 2 times with new filter, same. I clean the intake valve timing control and test it with 12dc and the ohme tester. Looks fine and still the same.
Bonus : After some tries to start and rev the engine, (p0340) are removed from obd scanner but at his place it come p0011. Any suggestion?
Ask for more info if u need and again sorry for my bad language
Old Sep 28, 2023 | 05:57 AM
iideadeyeii's Avatar
iideadeyeii
You should of probably properly diagnosed the problem instead of throwing parts at it
Old Sep 28, 2023 | 06:05 AM
Richma's Avatar
Richma
The problem now is there are codes p0340 and p0011. IVTC is working fine. camshaft sensor are change, but i remember now, at first time when saw p0340 there was a bank 1, now its just p0340, its not mention any bank.
Old Sep 28, 2023 | 11:08 PM
Richma's Avatar
Richma
Hello. New update. I just checked the oil pressure and its show 6 bar at 2k rmp
I will edit mu first post for more and clear info about the car
NardoZ
Oct 2, 2023 08:20 AM
BillB33
Australia/New Zealand
Dec 8, 2022 11:36 AM
monty2003
Jun 16, 2021 11:23 AM
GT-ER
Dec 17, 2013 08:43 PM
Darkstar52
Feb 8, 2013 08:12 AM
