Hello from egypt need help for 350z 04
Old Jul 16, 2024 | 04:45 AM
amrossama46's Avatar
amrossama46
Default Hello from egypt need help for 350z 04
Hello all
this is amr from egypt
i have 350z 2004
was overhauling the engine
and tried the ac and found that the blower is not working
changed it with brand new one which is working outside the car and not inside
tried to change the fuses and relay and still the same issue
The compressor works fine and the the clutch kicks
any help ?
Old Jul 16, 2024 | 05:44 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome Amir- how many miles are on your Z33? Is it a euro spec car or brought in from elsewhere? Have you charged the compressor before testing?
Old Jul 16, 2024 | 05:48 AM
amrossama46
Hello
its 161,000 miles and its brought from canada
Old Jul 16, 2024 | 05:49 AM
amrossama46
And yes checked the compressor charge and confirmed its working and the clutch kicking also the fan
Old Jul 16, 2024 | 07:56 AM
iideadeyeii's Avatar
iideadeyeii
Change controls
iideadeyeii
Have you checked the ribbon cable?
Old Jul 16, 2024 | 08:11 AM
amrossama46
yes its working fine without any crack
and the control unit made a live data using xtool and working fine
Old Jul 16, 2024 | 08:16 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
What's pressure on low and high? Plus, presuming full evac and charge, qty of 134?
Old Jul 17, 2024 | 05:39 AM
dkmura's Avatar
dkmura
Mic to the rescue!
Old Jul 17, 2024 | 06:49 AM
MicVelo's Avatar
Originally Posted by dkmura
Mic to the rescue!
Well, if it's just the fan unit, likely nothing to do with the state of charge BUT ruling out the basics of it being a thermal or pressure switch. Re-reading, it does sound like a connectivity issue in the cabin. But without putting hands on it.... just shooting in the dark without tracers.
Old Jul 17, 2024 | 05:05 PM
icer5160's Avatar
icer5160
I'm thinking wiring fault somewhere or bad AC control module. Have you been able to get a multimeter on the blower motor harness and see if you're getting 12V there? Check for a short to ground and verify you're getting power when the blower motor is commanded on.
Cheers!
-Icer
Old Jul 18, 2024 | 04:14 PM
dkmura's Avatar
dkmura
Amir- are you still with us? The whole community is offering some expert advice, but you're not responding.
Royal 350z
Apr 7, 2024 11:08 PM
ASM2010
Jan 17, 2014 08:22 AM
Speed4Life
Nov 7, 2012 05:46 AM
Barnabas
Mid-Atlantic
13
Mar 29, 2009 11:25 PM
