2007 350z soft top assembly replacement
Old Jun 17, 2025 | 05:28 AM
atrigz's Avatar
atrigz
Default 2007 350z soft top assembly replacement
Hi y'all,
After years of having my top tied down due to a bent frame, I have finally obtained a replacement! It seems pretty straight forward, but I wanted to check in here to see if there are any tips or tricks I should know about before getting started? I've been having the hardest time finding any videos or guides on the process. Thanks!
Old Jun 17, 2025 | 07:08 AM
Heel Til I Die's Avatar
Heel Til I Die
Good for you on tackling such a project!
I've attached the RF (roof) section of the FSM here. Hopefully it helps!
I'm not sure if there are any write-ups about replacing the entire roof assembly on here. There's a good one regarding the soft top in the roadster section.
Good luck and maybe start a DIY thread?
File Type: pdf
Old Jun 17, 2025 | 07:28 AM
atrigz's Avatar
atrigz
Thanks! This will be a helpful tool.
Good idea about the DIY thread as well. Never hurts to try other outlets. I'll update if I find anything of value.
rynev33
Aug 9, 2020 08:40 AM
jenner1
Aug 18, 2010 11:24 PM
xxForgedxx
Jan 26, 2009 08:20 PM
