HELP: Dead battery question
Old May 20, 2004 | 10:20 PM
zh.guitar's Avatar
zh.guitar
Leave your mark!
Default HELP: Dead battery question
My z is 1 year old with 7000 miles. I go on vacation and come back about 2 1/2 weeks later and it won't start. Dead battery. I jump it and it starts on the second try, no problem. I drive it for about 30 min to "charge" the battery. When I get home it is still dead. It took a little charge but not enough to start. Next I try to jump it again and it won't jump. Occasionally the starter will barely turn over but that's it.
What happened and what should I do now?
Old May 21, 2004 | 08:28 AM
Michael-Dallas's Avatar
Michael-Dallas
Test your battery and your alternator. You can use the volt gauge, but I would recommend using a multimeter.
To check the battery, start your 350 w/ all accessories (i.e. radio, a/c, etc.) off while somebody measures battery voltage. If voltage drops to < 10v, then your battery has a weak charge.
In this situation, I would pop the plastic terminals off the battery (if the battery isn't maintenance free), fill the 6 cells w/ distilled water, charge it w/ a battery charger, then try again. If the battery still has a weak charge, then the battery is bad.
To check the alternator, measure battery voltage while your 350 is running w/ all accessories off. It should read > 13v. If it's < 12v, then your alternator isn't charging the battery.
Michael.
Old May 21, 2004 | 10:20 AM
zh.guitar's Avatar
zh.guitar
Leave your mark!
good advice but I don't have a voltage meter and I can't seem to start the Z. I might just call the Nissan service center and have them pick it up and fix it.
Old May 21, 2004 | 11:50 AM
Michael-Dallas
In that case, then try using the voltage gauge in the center console. With the key in the acc. on position (w/ all accessories off), look to see if voltage reads > 12v. If it does, then try to crank the engine and watch the voltage gauge to see if it drops < 10v.
Michael.
Old May 21, 2004 | 02:34 PM
zh.guitar's Avatar
zh.guitar
Leave your mark!
Problem solved. I was able to jump it and took it to Nissan. They checked it and said the battery was a dead. They replaced it free under warranty.....
thanks for the help
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
Depravity
Oct 1, 2015 04:49 PM
