installed wing, now hatch keeps falling
Old Oct 8, 2004 | 02:27 PM
shanster's Avatar
shanster
Default installed wing, now hatch keeps falling
Anyone had a problem with the hatch not staying up after installing a wing? Put on a carbon fiber NISMO wing, and now the door keeps falling... Is that something i should take to the dealer or should i try to find stronger lift cylinders?
Old Oct 9, 2004 | 10:18 AM
slick099's Avatar
slick099
I have that same problem! I have a NISMO wing too but not CF unfortunately. Also when I press the button to pop the hatch I have to lift at the same time or the hatch won't open
Old Oct 9, 2004 | 05:19 PM
shanster's Avatar
shanster
Exactly! i have same problem with the button. It's a shame that the lifters and springs can't handle the small amount of additional weight of the wing. Let me know if you get it fixed! Thx
Old Oct 9, 2004 | 06:19 PM
shanster's Avatar
shanster
Hey, I saw this in a thread ..... Try it! I just got through, and it works perfectly!
Trying removing your springs, and inserting 2 pennies inside the rubber covering and then reassmble. I wrapped the pennies with a little bit of electrical tape to keep them from rattling.
I removed the ballast (square weight) attached to the underside of the hatch door. Remove the inside cover.
Now when i press the remote or button, the door springs open on the first try, and the hatch stays up all by itself!!
lapham3
Oct 7, 2022 03:15 PM
Mattg350z
Oct 2, 2015 06:51 AM
