P0444: Purge Control Valve?
Old Apr 25, 2006 | 05:28 PM
Question P0444: Purge Control Valve?
My SES light is ON. OBDII reads: P0444 An open circuit condition exits in the electrical circuit for the purge control valve in the evaporative emission control system.
a. I got the SES light ON immediately after installing the plenum spacer.
b. I can temporarily turn OFF SES by disconnecting battery for several hours. But when I restart car, SES come ON.
c. The car runs fine.
What is the purge control valve? Where is it? Is there a relationship between the purge control valve and plenum spacer?
Your help and comments are appreciated.
Old Apr 25, 2006 | 06:12 PM
DavesZ#3's Avatar
DavesZ#3
Oh, there's a definite relationship there. The purge control valve is the little unit connected to the back passenger side of the upper plenum. IIRC, it has a hose and a connector coming off of it. My guess is that you didn't reconnect the vacuum hose or it has a bad leak. The pic below shows where it is...
Attached Thumbnails P0444: Purge Control Valve?-snap.jpg
Old Apr 25, 2006 | 06:41 PM
Thanks. I printed the illustration and will check the hose tomorrow.
Old Apr 25, 2006 | 11:50 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Noobs take notice -
ask a good question and get a good response.
ask a noob question "OMG I got SES lite wut do I do" and get a bad (or no) response.
/rant
Old Apr 29, 2006 | 01:53 PM
Thanks for your help. I figure that before I try any complicated diagnostics, that I would search for something simple. And the solution was simple: I failed to connect the evap canister purge control solenoid valve.
Old Apr 29, 2006 | 02:27 PM
DavesZ#3's Avatar
DavesZ#3
Don't feel bad, we all do something stupid like that at one time or another. I was working on mine and had the BCM unplugged and tried to start the car. It won't start without all the connectors plugged in
Old Apr 22, 2009 | 09:05 AM
AznSky's Avatar
AznSky
Hmmm....I have the same exact SES, which came up the same way after I installed my plenum spacer. Even does the same exact thing by restarting the car.
I'm pretty sure I checked all my vacuum lines but I"ll check again. And thanks for the pic Dave
Old Apr 22, 2009 | 09:42 AM
Phreakdout's Avatar
Phreakdout
I'm very certain we hooked that hose up.
Old May 8, 2009 | 08:13 AM
crazeejitt's Avatar
crazeejitt
I have "PO444 PURGE VOLUME CONT/V" on my g35 coupe, could this hurt your car driving with this code?
Old Oct 15, 2009 | 10:51 PM
1FLUSHZ's Avatar
1FLUSHZ
i have this code also and i disconnected the valve and reconnected it, check engine light is still on..anyone know what wrong???
Old Oct 16, 2009 | 04:30 AM
AznSky's Avatar
AznSky
make sure the harness is connected as well, the one sitting on top the plenum. I forgot to connect mine which is why my light came on.
Old Oct 16, 2009 | 10:03 AM
1FLUSHZ's Avatar
1FLUSHZ
do you have a picture of the harness? my code reads EVAP emission control system purge valve C open, is it ok to drive wwhile this code is on?? please can anyone give me some advice or some helppp, id appreciate it
Rev_Night
Nov 7, 2020 06:00 PM
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
