Quick help: how to replace front wheels
Hey all,
I just put on my rear wheels but I'm having trouble getting the fronts on. Reason being is the pin that Nissan has on the front rotors so that you can't goof and put the rear wheels up front. TireRack's invoice says that I need a 12mm wrench to remove that pin... however... I can't obviouslly take it off otherwise the rotor will spin as I try to remove it. It seems tight.
What should I do at this point?
Have somebody apply the brakes while you turn the wrench. That will keep the rotor from spinning. That or use a big 7/8 wrench between the lugs to provide counter pressure. Trust me, that pin isn't in there that tight.
etkms
Jun 19, 2022 06:30 PM
seagrasser
Oct 11, 2015 03:27 PM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
Beater350z
Sep 9, 2015 03:36 PM
