Passing emissions in VA with FI?
Old Sep 13, 2005 | 11:04 AM
mbq62's Avatar
mbq62
Default Passing emissions in VA with FI?
I'm in the market for an FI system and would like to know if I'll have problems passing emissions. I've heard that as long as I have the cats I won't have trouble passing. However, I'd like to know from some of you in the area who have experience with this. Thanks!
Old Sep 14, 2005 | 08:57 AM
kcobean's Avatar
kcobean
If your tune is good and you give the car to the emissions guy with the cats good and hot, you shouldn't have a problem. I'm running catless and richer than Bill Gates, so I'll be shopping around for emissions under the table when my time comes.
Old Sep 14, 2005 | 04:27 PM
MCopare's Avatar
MCopare
Yup I have Vortech and just had the car inspected. I have High Flow cats and all they did was a visual inspection...no sniffer.
Old Sep 15, 2005 | 04:57 AM
mbq62's Avatar
mbq62
kcobean- why do the cats have to be hot?
Mcopare- they dont put the car on a machine? usually when i used to get my emissions done....like 2 years ago... they put this thing into your exhaust to measure something. this is in fairfax county va.
Old Sep 15, 2005 | 05:32 AM
CompiledMonkey's Avatar
CompiledMonkey
I don't think I've ever had emissions testing.
Old Sep 15, 2005 | 06:39 AM
h s2k's Avatar
h s2k
I have never had mine tested either....
Old Sep 15, 2005 | 06:51 AM
mdracer76's Avatar
mdracer76
The cats have to be hot.. because they are .. well.. catalyists.. the heat causes them to change the bad and unburnt things in your exaust into not so bad .. burn things.. lol
Also .. I dont think that people outside of the NOVA area have to do emissions.
here is a good link on how cats work
http://auto.howstuffworks.com/catalytic-converter.htm
Old Sep 15, 2005 | 07:22 AM
mbq62's Avatar
mbq62
^^ aaaahhh cool thanks! so i should track the car before going in for emissions lol hahaha
Old Feb 23, 2009 | 09:35 AM
hotpocket's Avatar
hotpocket
need to get emissions done in NOVS asap, can anyone recommend a place (that will pass me) near fairfax, reston, herndon chantilly area, wont mind driving a little either.
im running FI with no cats....
thanks
Old Feb 23, 2009 | 10:13 AM
WYZIWYG's Avatar
WYZIWYG
Nope. Every two years my Z and beater go to VEIP for emissions testing. I personally think it's a scam to suck more cash out of us, but what the hell do I know?
Old Feb 23, 2009 | 10:14 AM
djParis's Avatar
djParis
Retired Racer
As long as you don't have a check engine light, you should be fine. The sniffer test is a thing of the past. Visual inspection is another story.
Old Feb 23, 2009 | 11:07 AM
kcobean's Avatar
kcobean
I wouldn't be so sure about that. They check for more than just CEL's when they hook up to your car. They also look to see that all of the sensors report ready, including catalyst (which I *think* they do by looking for a change in emissions content between the front and rear O2 sensors). In a car with no cats, the emissions will be the same front/rear and your catalytic converter status will permanently be "not ready" which is an automatic failure. Your best bet is to pull your Y pipe if your configuration has it, put your cats back in, test, and then revert back. If you have something like the Turbonetics kit....good luck!
Old Feb 23, 2009 | 11:49 AM
hotpocket's Avatar
hotpocket
i have a turbonetics kit and a JIC full Ti single exhaust with out cats...
i was wondering if anyone knows a place that i can go to or anyone a can throw a few bucks under the table?
Old Feb 23, 2009 | 12:03 PM
kcobean's Avatar
kcobean
That's the problem with the new emissions testing systems. The computer that's interfacing with your vehicle's OBD-II system doesn't lie and it's tied directly into the state system so as soon as you fail, it's recorded. The only way I *think* you can 'cheat' is to use someone else's car. The reason I didn't do this when I had my T-netics kit was because I could never get confirmation on whether the VIN is available via the OBD interface. If it is, you can't do it. I don't think it is though, which means that would work if you can find someone with a stock car to help you out. I may know a place if you decide to go this route.
Old Feb 23, 2009 | 12:18 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
I passed emissions last year with no cats. All they did was the OBD-II check (I don't have any CELs). I'm good till 2010.
Old Feb 23, 2009 | 12:25 PM
kcobean's Avatar
kcobean
I knew if someone was going to come along and prove me wrong, it would be you, ya dirty rotten son of a *****.
So I guess I should say that based on MY EXPERIENCE, these are the difficulties with passing emissions with no cats.
Do you have O2 stand-offs on your car?
How you been brother?
Old Feb 23, 2009 | 12:53 PM
djamps's Avatar
djamps
Register in MD? I know here as long as the CEL/SES is off you're dandy.
Old Feb 23, 2009 | 12:54 PM
abui01's Avatar
abui01
Here's what you do:
1. clear codes
2. drive 50 miles
3. get emissions test
4. pass
At 75 miles or so, the check engine light will come back on, so do it before then and u're golden for the next 2 yrs.
Old Feb 23, 2009 | 12:57 PM
kcobean's Avatar
kcobean
Originally Posted by abui01
Here's what you do:
1. clear codes
2. drive 50 miles
4. pass
I tried this...several times. Never could get my car to pass. Perhaps I need more fries?
Old Feb 23, 2009 | 01:01 PM
superchargedg's Avatar
superchargedg
Damn Noobs
In MD all you have to be is dropped low enough so you cant get up over the rollers to the obd11 reader.I got a 2 tear waiver and they didnt even look at my car.
