Someone Help
Old Aug 4, 2006 | 10:38 AM
Zeus 350Z's Avatar
Zeus 350Z
Default Someone Help
Hey guys....
Someone PLEASE let me know if there is a place I can go into in Virginia that will pass me for emissions and regular inspection. I won't pass I know it, I have deleted cats exhaust and a supercharger. Please someone help me, if u can PM me!!
Thanks,
Zeus
Old Aug 4, 2006 | 10:53 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Looks like your fuked in the pooper to me....j/k good luck man
Old Aug 4, 2006 | 11:28 AM
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
yeah gonna be difficult. with no cats there is no way are going to "legally"
pass inspection as far as i understand it. i assume you looking for some of
the underground emissions facilities that look the other way while you pop
some cash in their hand... LOL.
Old Aug 4, 2006 | 12:05 PM
djParis's Avatar
djParis
Retired Racer
Lots of places are plugging into your OBD2 port now to check emissions. As long as you dont have a check engine light you should be fine at one of these stations. I had a friend pass with no cats. Its the sniffer test you have to watch out for.
Old Aug 4, 2006 | 03:01 PM
Sly_Z's Avatar
Sly_Z
In md 96 and higher get OBD2 plugged in, if VA is the same way you should be good just make sure you don't have any codes before you get there.
Old Aug 4, 2006 | 06:40 PM
350z+'s Avatar
350z+
pm me your phone number. I had the same problem. :-) I will call the tech who helped me pass tom.
Old Aug 4, 2006 | 06:51 PM
kcobean's Avatar
kcobean
Hey Zeus, this is one of the reasons I sold my car. Here in FFX and Loudoun Counties, the emissions program is all computerized. They plug in to your OBD-II system and pull sensor status on a number of sensors. Your O2 sensors will most likely show 'not ready', as will your catalytic converter status because the O2 sensors are not seeing the exhaust gas "lean out" between the front and rear readings (No cats=no hydrocarbons burned up).
I tried several times, but with no luck. I can hook you up with a guy for state inspection, but that's a human administered test, so it's easy.
Good luck man...you know what it's time to do.
Old Aug 4, 2006 | 06:53 PM
kcobean's Avatar
kcobean
This isn't true here in VA. I had no codes when I tested and I failed every time. I even plugged my scanner in just before the emissions guy plugged to make sure. It's possible to have no DTC codes active and still have your sensors indicate 'not ready'. Once that happens, you're done for.
Old Aug 4, 2006 | 09:30 PM
arjunz's Avatar
arjunz
I wonder how those mustangs with straight pipes pass their emissions ... i see enough everyday!!
Old Aug 4, 2006 | 09:33 PM
mdracer76's Avatar
mdracer76
They put thier cats back on .. test and then go home and put thier test pipes back on
Old Aug 4, 2006 | 10:18 PM
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
^^ yeah that's what i was gonna do when i had my stillen race pipes. but
just went ahead and got some hfc's.
