FS: Local Only Hotchkis Stage 1 TVS
Old Oct 21, 2006 | 09:13 AM
djParis's Avatar
djParis
Retired Racer
Default FS: Local Only Hotchkis Stage 1 TVS
Brand new still in the package.
$400.00 Come get it
I am located in the Centreville/Fairfax area.
Old Oct 21, 2006 | 10:13 AM
abui01's Avatar
abui01
i want it!!! just kiddin, whoever buys em will be very satisfied w/ the ride quality of the springs + drop, the Hotchkis bars are great for daily driving!
Old Oct 21, 2006 | 10:24 AM
Ilov350ZEE's Avatar
Ilov350ZEE
how much do they lower?? do i need to have a set of new struts and camber kit???
Old Oct 21, 2006 | 11:49 AM
djParis's Avatar
djParis
Retired Racer
All I know is they were designed to work with OEM struts, thats why I bought them. I am unsure about the need of a camber kit, I would say no since they don't slam the car out like some of the other springs, but then again I havent really looked into it. Does anyone else know if you need a camber kit?
Old Oct 21, 2006 | 01:07 PM
Ilov350ZEE's Avatar
Ilov350ZEE
how much do they lower???
Old Oct 21, 2006 | 01:19 PM
Nexx's Avatar
Nexx
they lower .6 in the front and .7 in the rear.
Old Oct 21, 2006 | 02:08 PM
abui01's Avatar
abui01
anything over a 0.7 inch drop requires a camber kit. But in other words, nope! These work with your stock shocks
Old Oct 21, 2006 | 03:18 PM
in2therain3's Avatar
in2therain3
Just wondering but what are the spring rates on the hotchikis springs?
Old Oct 21, 2006 | 04:21 PM
Zincognito's Avatar
Zincognito
hmmmm.......i think i want em.....
Old Oct 23, 2006 | 03:26 AM
suprpwr's Avatar
suprpwr
hhmm...what's the install like on something like this? (especially with the springs)....hhmm.....very tempting....
Old Oct 23, 2006 | 04:02 AM
TZCCVA's Avatar
TZCCVA
Quote from Hotchkis:
Hotchkis Tuning Sport coils offer the performance you seek, and the comfortable ride you deserve. Made from cold wound silicon steel, our springs are linear rate, and are powder coated seabring silver.
Front Front 9/16" (15mm) Drop
340 lbs/in
Stock 310lbs/in
Hotchkis Tuning Sport Sway bars improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with our track tested lightweight hollow sway bars. Sway bar sets include front and rear bars, greasable bushings, and brackets. Bars now come with welded retaining rings.
Specs:
Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs)
4 Position Adjustable
Rear 15/16"(24mm) Tubular(bar weight 5.5lbs)
3 Position Adjustable
Bar Rates:
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock)
Hole 2 = 1845 lbs/in (15% Stiffer than stock)
Hole 3 = 2270 lbs/in (42% Stiffer than stock)
Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
