Local built motor, fuel system, and engine management swap?
Old May 20, 2008 | 11:58 AM
ILLBZNU's Avatar
ILLBZNU
Default Local built motor, fuel system, and engine management swap?
I am wondering if anybody would be interested in trading my built motor, fuel system, and UTEC for stock replacements plus cash? I would like to sell everything a a package, but I will consider selling separately once the engine is spoken for. Individual prices are posted below I have tried selling the car as a whole with no luck. I have a daughter on the way in three months and am running out of time. So I am trying a different approach...
The Motor has 2,500 miles on it and only 300 of those with a turbonetics setup on it. I gave up on going the turbonetics route (as have many others) and never got a chance to follow though with my ultimate setup. $4,850
· Built by Bob Hamilton in Delaware (using the most up to date machining equipment available and on display at the 2006 SEMA show).
The block and head was redecked.
Block and head oil passages were cleaned.
The crank journals were polished and the crank was balanced.
New valve stem and cam seals were installed.
Valve stem heights were set.
All new timming assembly was added.
The cold clearance was set.
· Arias Extreme Duty 9:1 pistons
· Pauter Rods
· Nismo High Flow oil pump
· ½” ARP head studs (Block and head was CNC machine honed and drilled, not from template which is commonly done)
· Coolant bypass modification (allows extra coolant to the back side of cylinders utilizing the OEM Pathfinder coolant duct.)
· 3 angle valve job
· Heads were ported and polished
The Fuel System:
· Full CJM STAGE 2 fuel return system with larger return lines, new fuel rails, and Aeromotive regulator. with Walboro 255 fuel pump (2,500 miles on it) $900
· RC 650 injectors with spacers and clips $800
The Engine Management: $700
· UTEC Parallel Engine Management System which allows full control over Fuel and Ignition Timing. Each control gives you 250 rpm resolution from 500 rpm to rev-limit with over 10 different load sites.
· DTEC-MAP is a plug-in manifold absolute pressure sensor that allows the DTEC to measure and data log boost pressures.
· Boost Control Solenoid
· Map Switch which allows you to switch between 5 different maps on the fly. (2,500 miles on it)
Old May 20, 2008 | 01:50 PM
Eric the Ricer's Avatar
Eric the Ricer
How much money are you looking for?
Old May 20, 2008 | 02:37 PM
citymunky's Avatar
citymunky
+1
Old May 20, 2008 | 02:52 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by ILLBZNU
Why are you posting in this thread?
I will be figuring up individual prices on everything tonight due to recent requests for individual items. I appologize for not figuring it out prior to posting.
I might be interested in just the motor.We could have Dave at FunctionTuned do the swap.
Old May 20, 2008 | 02:55 PM
bigslim350Z's Avatar
bigslim350Z
uh oh.....
Old May 20, 2008 | 02:56 PM
superchargedg
Damn Noobs
Originally Posted by bigslim350Z
uh oh.....
Yea man if the deal is right here comes some more psi........................oh and a built trans too.I just cant let Bert and Bryce have all the fun.
Old May 20, 2008 | 02:57 PM
bigslim350Z
damn, wish I had the funds right now too, a fully assembled engine swap would be easy.
If you could get it done quickly, are we going to see a low 11 sec car at track day?
Old May 20, 2008 | 03:29 PM
NX2KDET's Avatar
NX2KDET
Cpt. Nauti Raw
Cuz its not completely built
Old May 20, 2008 | 04:39 PM
ILLBZNU's Avatar
ILLBZNU
Default fine by me
That would be fine. Dave knows my car well. He personally has done compression tests and leak down on the motor with very good results. I had someone PM me ealier, and I want to give him a chance to respond by tomorrow AM. If he doesn't you've got dibs.
Old May 20, 2008 | 04:43 PM
Motero's Avatar
Motero
Originally Posted by NX2KDET
If you read my profile I have S1 cams JWT shim kit and valve retainers, pauter rods, JWT pop charger, AAM intake manifold spacer and some other goodies, its a good daily driver motor it has stock compression still, only has about 18,000 miles on it. It was built by SGP in texas.
Who gives a ****...
Old May 20, 2008 | 04:48 PM
NX2KDET's Avatar
NX2KDET
Cpt. Nauti Raw
Originally Posted by Motero
Who gives a ****...
I was just throwing an offer out there, I still have stock compression he said he wanted to trade motors but I didn't know you guys would respond with such flamboyancy and get butthurt about it. <3 U!
Old May 20, 2008 | 04:52 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Nice, hope this deal works out man would be fun to have another monster on the streets
Old May 20, 2008 | 04:55 PM
superchargedg
Damn Noobs
Right now im just a mini monster.
Old May 20, 2008 | 05:36 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Lol it's all fun man!
Old May 20, 2008 | 06:43 PM
Driven1's Avatar
Driven1
Professional
Do you have any of the spec sheets on this motor?
Old May 21, 2008 | 04:33 AM
ILLBZNU's Avatar
ILLBZNU
Default No spec sheet
I believe the builder told me that it took 9lbs of force to turn the rotating assembly, which he said was very good. And the compression and leak down had very respectable numbers as well. That's all I know
Old May 21, 2008 | 06:40 AM
kcobean's Avatar
kcobean
When I read your post the first time, it sounded like you were stomping on the thread rather than proposing your engine for the swap. Sounds like the OP is looking for "more stock" than you have to offer though.
Old May 21, 2008 | 06:55 AM
ILLBZNU's Avatar
ILLBZNU
You are correct. I would prefer a completely stock everything in exchange for my parts. and preferably an engine that is in good shape and has never seen FI. I'm not set on the non FI part, but it would definately be prefered.
Old May 21, 2008 | 07:38 AM
NX2KDET's Avatar
NX2KDET
Cpt. Nauti Raw
Oh kelly I don't think you remember me we talked at F:T for quite some time at the Z BBQ not too long ago but no I was just offering my set up that I thought would be a good DD setup hence the stock compression.
Old May 21, 2008 | 07:42 AM
ILLBZNU's Avatar
ILLBZNU
No prob. Thanks for the offer, but right now I'm more concerned with getting the money out of my car. I'm sure you wouldn't to give me my full asking price with trading your already built motor. Thanks anyway though.
