u want a 1/2 inch of play goin up and down when u push on the belt...roughly 15lbs of pressure according to procharger...i still have the manual....lol
Thanks for the help fellas. No vibrations or issues with belts snapping yet! haha But I did loosen the belt as described with 1/2 play. This is the 7lb pulley. Anyone know where I can upgrade the pulley other then calling procharger? Might as well upgrade pulleys and buy a new belt now ya know
Try searching the classified section.
Remember, as you upgrade the pully, you add PSI. Make sure you are set up to add more boost, so you don't damage or blow anything.
AAM is one of the authorized dealer for ATI parts. You can get up to I think 17 lbs pulley. But be prepared to spend a lot of money on replacing the front cog belt.
