A/F questions
I recently installed an AEM wideband. I was thinking it would be more stable but it turns out that it's too accurate and ends up bouncing like a mad man (it does idle around 14.7 give or take). I did some research and found out that it's normal until you hit boost. But when I hit boost, it just just flatlines at 10.0 which i find weird. I think my tune is supposed to be in the mid-11s. My tune was done by dave and it's running on utec.
Question:
1. is the sporadic A/F movement normal when not in boost?
2. any idea why i get a 10.0 A/F in boost? retune?
Thanks,
Khoa
Question:
Thanks,
Khoa
The A/F constantly changing is ok when on the throttle cruising. Ideally you want to cruise around 14.7:1, give or take some.
The AEM does not read richer than 10:1 A/F
If when you are WOT its stuck at 10:1, then your tune is at that spot or RICHER constantly. You do not want a tune that rich @ WOT or anywhere. Does the car feel like it falls on its face in the upper rpm's? Where is the sensor located?
Question:
Thanks,
Khoa
Question:
Thanks,
Khoa
Not normal if by sporadic you mean its jumping all over the place (14,15,17,14,) and not just flickering around fairly constant a/f numbers. Any idle or low throttle issues?
Maybe temp compensation needs adjusted? Too rich, Get a re-tune, I'm sure if you call Dave he'll get you taken care of.
Also check the AEM wideband - I've seen them go bad a million times. Check the voltage on the sensor.
Question:
The thing is, it got tuned last august and earlier this year, i had to get the map reloaded on a new utec. I just never got around to installing the AEM gauage. I was afraid that the gauge might be bad, but it seem to be operating normally. By sporadic, i meant that it's hovering. I was under the impression that the wideband would give a stable reading but i've read that it's so accurate, that it's constantly reflecting the live reading. How can I diagnose the gauage? it does idle around 14.7 give/take (.5-.7) or so. It does adjust when i'm in boost, it just goes pig rich from the reading, which is odd. I probably will bring it back to dave.
note: Thanks for the response Clint and Alberto
Watch this video, and watch the A/F guage on the pillar. When your off the throttle you may continue to get a reading for a split second then it will likely read lean, only due to lack of fuel from you letting off, that is normal. Otherwise the A/F's should hover near your tuners target as you are accelerating. See my car in the mid 11's, then go near 11:1 up top and even hit 10.9 for a split second. This is normal WB action....
http://www.youtube.com/watch?v=xGcJRE5Fn1s
AEM wideband is tempermental on placement as well, on wifes evo made a huge difference moving it from rear of front pipe to just after 02 housing. And a slight variance in AF with a UTEC is normal before switch over as it is still running on factory ECM looking for ideal AF.
Every wideband I've attempted to use so far is inaccurate and pretty undependable. It has needed to be recalibrated or just stops working. I don't depend on the actual reading but more know what my car should be at. My other gauges can tell me if something is really wrong.
The last one I had at one point said I was cruising at something like 24:1 lol which u know can't be true. hahaha
Everything else everyone said is true...placement, etc. If it was running that rich, you'd notice a difference in the way the car drives.
Have you called Dave about this yet and gotten his opinion?
Question:
Yo, Clint,
I needs me a HKS Turbo Timer Type-1. Do you guys have these in stock? I always forget to leave my car running for 30 to 60 secs after I get to my destination, cause I am a NEWB!!!!!!
LOL.. Hit me up and thanks.
- JB
