Question
Old Aug 22, 2011 | 11:06 AM
AlexJ_350z's Avatar
AlexJ_350z
Default Question
I think it might be an oil pressure problem. Dont know if anybody else has had this same problem. I have an 06 manual Z. I first realized it when shifting. When i shift into 3 gear and fourth there is a lag when pressing on the gas. It winds up now before i get that inicial power and I dont have the immediate thrust I usually have when i hit the gas. When I am idleing my oil pressure gauge in right under 30. When it is running I am right under 60. I really dont remember it ever being like that. Just wanting to make sure this sounds right. Open for suggestions. Thanks.
Old Aug 22, 2011 | 11:24 AM
Jgrizzle's Avatar
Jgrizzle
Have you checked the oil? Sorry if this is a dumb question....
Old Aug 22, 2011 | 11:48 AM
AlexJ_350z's Avatar
AlexJ_350z
yea i have. it is filled
Old Aug 22, 2011 | 12:23 PM
KAT_Ayanami's Avatar
KAT_Ayanami
Is the clutch worn? Do the revs go up but the car does not go?
What color is your Z?
Old Aug 22, 2011 | 02:32 PM
AlexJ_350z's Avatar
AlexJ_350z
Well the car goes. It doesn't seem like the clutch the clutch in-gauges. AND now on my way home it idled as low as almost zero. It is red.
Old Aug 22, 2011 | 03:51 PM
KAT_Ayanami
Dumb question here:
Do you have the check engine light on?
Old Aug 22, 2011 | 04:19 PM
AlexJ_350z's Avatar
AlexJ_350z
Nope no engine light...thought there would be with this **** going on.
Old Aug 22, 2011 | 05:28 PM
bb1314's Avatar
bb1314
da Terminator!
Maybe some clog in your injectors? Probably had a bad tank of gas? This issue sounds familiar.
Old Aug 22, 2011 | 06:06 PM
Alberto's Avatar
Alberto
Cranky FI Owner
vacuum leak
clogged cats? high mileage car?
oil pressure seems fine
Old Aug 22, 2011 | 07:01 PM
jeffie7's Avatar
jeffie7
Check for codes anyways. A lot of codes won't throw a light but will cause a code to show up.
Old Aug 23, 2011 | 03:18 AM
AlexJ_350z's Avatar
AlexJ_350z
Thanks guys. Ill take a look into that. Mileage is only 53,000. Just hate the feeling when something isnt running right. So just want to make sure. when idling zero is ok? never seen it that low before in the past.
Old Sep 9, 2011 | 07:09 AM
AlexJ_350z's Avatar
AlexJ_350z
Found out what the problem was. IT was my oil pressure sending unit. And my flywheel. Need a new clutch kit. Just purchased a double friction centerforce clutch kit. Thanks guys again
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
