mods
Old Mar 12, 2012 | 08:14 AM
hueyja's Avatar
hueyja
Default mods
ok so what exactly does the fuel return do for the z? also can i put 550 injectors on the car with no tune or will i be running too rich ?
Old Mar 12, 2012 | 08:25 AM
Alberto's Avatar
Alberto
Cranky FI Owner
No.
Old Mar 12, 2012 | 08:36 AM
ZS14RR's Avatar
ZS14RR
More info about the vehicle.
Old Mar 12, 2012 | 10:03 AM
MUZZY's Avatar
MUZZY
Just stop whatever your doing. please do more re-search.
Old Mar 12, 2012 | 10:18 AM
jeffie7's Avatar
jeffie7
Is this going on an RSX Type S?
Old Mar 12, 2012 | 11:59 AM
hueyja's Avatar
hueyja
im tryin to do my research just dont no where to start. there is not a lot of forums to help and people go off subject way too much. i have a base model 350z 2003
Old Mar 12, 2012 | 12:00 PM
jeffie7's Avatar
jeffie7
There's tons of info on my350z.com enough to build your own custom turbo kit or even do an AWD swap.
You just need to either search around for the info that is already out there or at the very least ask the right question.
Old Mar 12, 2012 | 12:02 PM
bb1314's Avatar
bb1314
da Terminator!
Old Mar 12, 2012 | 12:05 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Why do you think adding more fuel to a stock car would yield better results?
Go learn the basics of how an engine makes power before you come here and try to add BS mods to your car.
No excuse for not having knowledge in this day and age.
Old Mar 12, 2012 | 12:06 PM
thisishk350's Avatar
thisishk350
It'll run awesome... lol
Old Mar 12, 2012 | 12:28 PM
steven350's Avatar
steven350
if you have a problem with this search engine, an easier way is to go to google and type my350z(space) ______ <- and your question...
Old Mar 12, 2012 | 12:59 PM
thisishk350
lol whut? You're on the forum that helps... SMH
Old Mar 12, 2012 | 02:07 PM
jeffie7's Avatar
jeffie7
site:my350z.com (space) question
Old Mar 12, 2012 | 02:51 PM
abui01's Avatar
abui01
Stop giving so much trouble to the new dude guys.
Anyhow, to answer your question - you'll need to upgrade your fuel return system if you want to run larger injectors. If you read up on shop builds, the larger CC injectors, the more fuel it injects into the cylinders thus creating more power. Stock injectors are crap, 550cc's are sub-par. If you want big power, go with anything above 1000 CC's.
With the added fuel, you'll need a good engine management system. There's this local guy "i3aoG" selling a Greddy E-manage that you'd want to pick up for a steal. Heard he only wants $300 for it. With this unit, you can maximize the fuel output w/ your stock fuel return system and 1000cc injectors.
As someone has mentioned before, "learn how the motor works." I can give you a brief rundown. A motor sucks in air from the outside, mixes it with fuel, the sparks create a combustion which yields you power. If you're already upgrading your fuel, you need to upgrade the other three: intake, spark, and combustion.
Intake - you want low density air for maximum results. A lot of folks on here have front mounted cold-air intake systems. You can get them for fairly cheap on e-bay.
For example, bb1314 has a front mounted intake cold-air setup:
and this guy named Alberto:
Jeffie7:
i3aoG also:
You can PM any of those guys, they have been having great results.
Spark - you can achieve greater spark by purchasing a grounding kit. It yields anywhere between 15-20whp. Most vendors on here sell them.
Combustion: you want to lower your compression in order to achieve more power. Take a look at all the big horse power builds on the forum, they're all running 8.0.1, 8.5.1, 9.0.1 etc. Anything over 9 is too much compression for a naturally aspirated engine. Lower = More power. You can achieve this buy purchasing a thicker head gasket. Companies like Cometic/Cosworth sell great ones. If you're on a budget, people have gone to the dealer to purchase two "HR head gaskets" and stacked them on top of one another. This also works out great.
Good luck on the build.
Old Mar 12, 2012 | 06:06 PM
vtchang's Avatar
vtchang
cold blooded...
Old Mar 12, 2012 | 06:33 PM
beenthrdonetht's Avatar
beenthrdonetht
abui01 summed it up for you.
Old Mar 12, 2012 | 07:50 PM
i3aog's Avatar
i3aog
It's true, Greddy E-Manage f/s
Old Mar 12, 2012 | 09:13 PM
hueyja's Avatar
hueyja
ill do my research. just so u guys no im a diesal mechanic for ford been doing it for 4 years i apoligize for dumbing myself down but sometimes its the best way to get answers sad but true. i already plan on lowering my compression and improving fuel pressure im also going to put cams and much more aggressive valve angles. i was trying to understand what mopds to do first on a z figured u guys would no since u have had them longer and i figured that the fastest way to learn was to simply ask.
Old Mar 12, 2012 | 09:16 PM
jeffie7's Avatar
jeffie7
What is your end goal? Why do you want to lower compression?
Old Mar 12, 2012 | 09:18 PM
ImWeeZzel's Avatar
ImWeeZzel
^^^If I hadn't bought an xbox this weekend, I would've picked it up from you br0.
too bad I haz no moneys at the moment
