wierd electrical problemunderdrive install
Old Mar 16, 2012 | 05:16 PM
hueyja's Avatar
hueyja
Default wierd electrical problemunderdrive install
ok guys can anyone tell me why when i go over 4 grand my battery and brake light start flashing on my dash the brake is down and my voltage is good??? it started happening after my underdive install today.
Old Mar 16, 2012 | 05:56 PM
Barnabas's Avatar
Barnabas
National Z Club President
loose connection somewhere, when you rev the engine moves must be shaking something enough to cause the lights to come on.
Old Mar 16, 2012 | 07:28 PM
ZS14RR's Avatar
ZS14RR
Injectors too big.
Old Mar 16, 2012 | 07:43 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Are you sure it isnt actually getting back up to normal brightness? It may be under-driving the alternator and at idle or low rpm's everything is actually slightly dimmer? Then you rev it up and the lights get brighter. Put a multi-meter on the battery and check this, it may be a voltage jump.
Old Mar 16, 2012 | 09:13 PM
hueyja's Avatar
hueyja
i have stock injectors. i will look at my voltage but i do not think its going from dim to lit because when u turn the key to on but engine off it lights up like its suppose too. i also changed my brakes today im kinda wondering if i messed up the brake cable on accident when i did the back brakes.
Old Mar 17, 2012 | 03:21 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Make sure the brake fluid isn't low as well.
Old Mar 17, 2012 | 05:30 AM
djamps's Avatar
djamps
+1 low fluid. no idea on the battery light, check engine grounds and batt/alternator terminals
Old Mar 17, 2012 | 02:58 PM
KAT_Ayanami's Avatar
KAT_Ayanami
What pulleys did the underdrive kit came with?
Are you SURE you put the one for the alternator on the alternator??
I think that the problem is that you put a smaller pulley on the alternator, making it work at a faster speed than normal. And when you go over 4,000 rpm, your voltage increases and goes over the maximum limit, which makes the battery light flash.
The flashing means to stop INTERMEDIATELY if you want to avoid damage to the car).
Just check what voltage are you getting on the center gauge, and check if you did not mixed the pulleys up.
Old Mar 17, 2012 | 02:59 PM
KAT_Ayanami
Oh, also check that you actually put the belt the way its supposed to go. It can also cause that issue.
Old Mar 17, 2012 | 05:32 PM
bb1314's Avatar
bb1314
da Terminator!
+1 on checking brake fluid level.
Old Mar 17, 2012 | 10:33 PM
abui01's Avatar
abui01
+2 on the brake fluid level. Most electrical gremlins are due to low fluid levels in this car whether that be the brake fluid, power steering fluid, transmission or even coolant levels. Low fluid forces pulleys to overwork themselves in order to use extra force to pump the low levels into the appropriate places of the motor/car. Often times, this puts extra strain on the alternator and causes it to draw current away from your main power supply. This chain reaction usually causes cluster lights to flicker.
Old Mar 18, 2012 | 04:52 PM
KAT_Ayanami
Wait... by "the brake is down" he means that the pedal goes to the floor? Or that he has no brakes?
wanderingstuden
Jan 28, 2016 07:03 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
